Does anyone have any tricks for using stencils that use Oracal vinyl material?
The problem I have is that when I peel the backing off the stencil, the glue is so strong between the backing and the stencil that it stretches the vinyl material and leaves air pockets which are really difficult to get out. It also wants to pull the stencil material off the cabinet.
These are the stencils I'm using from Marco. http://www.marcospecialties.com/pinball-parts/CA-496-SK
I noticed that if I pull back on the backing at as close to a 180 degree angle as possible it helps, but that is really tough to do, and is only slightly helpful.
I'm wondering if there are any tricks to making this easier.
