(Topic ID: 18292)
VID's Guide to Upgrading/Rebuilding Flippers
By vid1900
10 years ago
  • 2,836 posts
  • 476 Pinsiders participating
  • Latest reply 1 hour ago by Dakine747
  • Topic is favorited by 1,315 Pinsiders
15 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 2,836 posts in this topic. You are on page 57 of 57.
#2801 6 months ago
Quoted from runpatboyrun:
Is there any chance that these parts could be found six years after this post was posted?
All links to Pinball Life are dead and I was wondering where to look for a WPC flipper mech upgrade for a Xenon.
runpatboyrun - Pinball Medics has both rebuild kits and full assemblies, and they have a Montreal location you may be able to pick up at. Regardless, their shipping is lightning fast.
#2802 6 months ago
Quoted from mIkea:
I've already rebuild with a kit I purchased from them. It's time to upgrade!
ç
#2803 6 months ago
I did a flipper rebuild on my Bally X's & O's including the flipper switches as they were badly pitted. I'm getting some sticking of the flippers on the right side. While investigating, I noticed that the flipper switch itself on that side seems to be sticking. I cleaned with alcohol but still happening. Can the flipper switch itself magnetize somehow? I widened the gap a little to see if that would help, but still happening. It seems to start after a few minutes of play, so it builds up over time.
#2804 6 months ago
Quoted from JRC6000:
No, but the arc can weld them together. You can file a 'crown' onto one of the switches to prevent this. (or both but I usually just do one).
You can also add a capacitor to the switch to reduce the arc.
#2805 6 months ago
ç
They should have WPC mechs/parts as well if that’s what you’re looking for.
#2806 6 months ago
Quoted from slochar:
OK, sounds like adding a capacitor is easy enough. Just solder between the two tabs, right? Never done this before, what capacitor do I need? I'm about to place an order with PBResource, so easy to add. There are a ton of things on that page! Any idea which I can use?
http://www.pbresource.com/eleccomp.html
#2807 6 months ago
.1 uf @ 500v (or higher) ceramic disc capacitor
based on earlier posts. I think that's what german games have on them to reduce the sparking.
I've never had to do anything other than shape the contact though. (assuming you don't have something else like something hanging on the PF causing interference)
#2808 5 months ago
Greetings - Possible to get some insight on my Fathom flipper issue? I am trying to wrap my head around how the two flippers on the right work off of one switch. The normally open and normally closed comments in the schem... Maybe this is easier than I am making it out and a problem between the floor and the machine (me). I am sort of a noob at these circuits and the fine tweak experience is what I lack. Everything is new including the coils.
Lower right flipper works perfect. Upper right is weak and sometimes doesn't kick at all.
All 3 coil windings appear terminated to the solder post and diodes check out. Wiring looks ok as far as I can tell, 85 is black/white on both etc.
Some switch adjustment opinions welcomed. I agree with all Vids comments on the linears IE heavy, sloppy minimal/tangent contact on plungers etc. Will convert them on my PF swap. Just trying to gain a little more insight on this 2 flipper/one switch scenario.
Pics are under power lower right powered, unpowered - upper right powered, unpowered
FLIPPER_SCHEM_PIC (resized).JPG_1_LOWER RIGHT NO POWER (resized).jpg_2_LOWER RIGHT POWERED (resized).jpg_3_UPPER RIGHT_NO POWER (resized).jpg_4_UPPER RIGHT POWERED (resized).jpg
#2809 5 months ago
Use sandpaper to clean the outer switch on the lower right flipper. That switch provides power to the upper flipper. New high power switches (big contacts) can often be oxidized, causing resistance. Can't see the oxidation, but if you measure resistance across the closed contacts, you can measure it. Should be less than 1 ohm resistance. If more than 1 ohm, sand until it's under 1 ohm. 400 or 600 grit works fine on new switches.
Also make sure the switch contacts are meeting evenly when closed. Contacts look a little off in pics, but may be ok once switch is closed.
#2810 5 months ago
My first time rebuilding flippers... Doing it on my recently acquired LOTR, because I wasn't sure of the condition of it. Glad I tore it all down as it was dirty and some things (bushings, eos switch) needed replacing. But the plunger/link assemblies and stops actually seem in great shape, not many miles on them in my novice view. I went ahead and used all the new parts from my rebuild kit, but should I hang on to these for a future pin/rebuild? They are slightly different make, but seem equivalent.
#2811 5 months ago
Very common for the EOS bracket to break on Stern's, so yeah, hang on to the old parts.
Stern links often wear where the bushing goes. Can't see the wear looking at it, but can feel the excessive play caused by the wear by wiggling the parts back and forth. Once disassembled, you can see the wear in the link hole.
#2812 5 months ago
I have a box of old flipper parts just in case something is out of stock or shipping takes too long.
I generally buy plunger/links, coil stops, EOS, sleeves, and bushings in bulk its much cheaper than buying kits.
Make sure the link has the metal insert washer in it. I've changed out many loose plungers that were metal on plastic. These are also something to have on hand because they are easy to drop when installing.
#2813 5 months ago
Quoted from phishrace:
Thanks. I attached a meter to the upper EOS and although it looked like it was making a good connection, the tension on the switch was extremely light. When the lower flipper actuated, the vibration caused the upper EOS to open early/intermittently. I tweaked the upper (then all the EOS switches) to be more under tension preload and it's all good now. I see why some of the later switches have an additional metal backer leaf on them now as Vid pointed out earlier. Live and learn
2 months later
#2814 83 days ago
I just rebuilt the flippers on my ID4, but now the left flipper seems awfully loose. If I try to dead bounce off the left flipper, the ball will hit the flipper and just lose all momentum and roll down the flipper into the drain. It's like the flipper is a shock absorber or something because there is so much loose play in it. I have rebuilt many flippers before but never had this issue.
Anyone else have this issue before?
#2815 83 days ago
Quoted from Bugsy:
Maybe it is binding up at the bushing, or the return spring is too weak to bring it back to fully down position. Did you replace both in the rebuild?
#2816 82 days ago
Posting some pictures of what my new Motordome’s old lower two flipper mechs are like. Pretty amazing to me that the right one hasn’t busted off (missing screw, loose, spring shot). Will be following the early Vid guide on upgrading these. Now to call Steve and not get yelled at…
Left Flipper
Right Flipper
Right EOS Switches
Right Flipper
Left Flipper
Upper Right Flipper
Upper Left Flipper (raised)
#2817 82 days ago
^ Dat iz somtink!
Your coil stop mounting holes in pic #2 may be stripped out, especially if someone rammed sheet metal screws into the holes.
Tap the next size up threads into it, or swap the left and right base plates (assuming the threads are virgin on those)
3 weeks later
#2818 60 days ago
Does the flipper build for the 6803 Bally (Motordome) need a capacitor to increase the life of the switch? Also, what do you put on the crank so it's not metal on metal contact? Electrical tape? Is that to avoid wearing the metal switch, or to avoid electrical currents? Thank you
#2819 60 days ago
Quoted from MiniPinHead:
No cap
You can put shrink wrap on the Crank (the hard plastic-y shrink, not the soft rubber stuff)
#2820 60 days ago
Quoted from vid1900:
No cap
You can put shrink wrap on the Crank (the hard plastic y shrink, not the soft rubber stuff)
Is there something preformed, like I'm seeing on other switches. Or do you have a link to your favorite material? Sorry, I'm really not sure if I'm supposed to be using Glad here, haha. I was thinking heat-shrink tubing for wires, but it's too small.
#2821 60 days ago
Just get the cheap stuff @ HF
https://www.harborfreight.com/5-16-inch-x-8-ft-black-heat-shrink-tubing-66767.html
#2822 46 days ago
Is the nylon and the washer in the correct place and direction? They’re hidden in a lot of photos.
Look away, I’m hideous! (old coil)
I don’t even want to think about all the things wrong with that coil. Saying “replace” over and over is like word bleach
#2823 46 days ago
The flanged end of the sleeve goes towards the coil stop
I've heard both ways on the spring washer. I put them on the coil stop, reasoning being that when the flipper fires, the coil gets pulled away from the coil stop, so seems like you'd want a solid connection on the other end?
#2824 46 days ago
This way with the washer would mimic how it was originally installed, taking into account Vid’s improvements. Is that acceptable?
This might be overkill, but if the washer has a slight bend to it, do you want the bend facing the coil or the metal? I was thinking the coil, so the metal takes the sharp edges and not the nylon of the coil.
#2825 45 days ago
Flanged end of the sleeve goes at the coil stop end.
Wavy washer goes on the non-flanged end.
https://pinside.com/pinball/forum/topic/vids-guide-to-upgradingrebuilding-flippers/page/15#post-2235465
1 month later
#2826 9 days ago
Thank you all for the help and posts, especially you Vid. Finally made one of the modified Bally flippers. Utilized some stainless steel hinges to make the L brackets so they’d be strong and snug, and trimmed some stainless steel machine screws so the switches wouldn’t short out on the crank screws that stick out pretty far. Going the Molex route for reconnecting the wires (much easier for a newbie solderer). Actually enjoyed the soldering part of the process. The annoying part was realizing I needed a vice to enjoy those manly minutes in the garage Vid talked about Thanks again for the Flitz recommendation - cleaned things up nicely
60488E6A-C942-4B98-AFCE-569E8869D6A8 (resized).jpegC73B7B97-91A7-4C8C-8E9E-3FAF304793FF (resized).jpeg9E76667B-62EE-41C6-9440-7EE8CEE07989 (resized).jpegAFA9FFA6-430C-49CF-93D0-21A5E22FCF49 (resized).jpeg6832201F-F427-457B-9FED-4F52EBA14E5A (resized).jpeg346A76A0-9924-49C0-8A67-99665B6CD9D5 (resized).jpeg
#2827 3 days ago
Did the second flipper. Read about Loctite 242 / Blue. Utilized that, including removing the first flipper to reassemble and apply it to the screws. Having the Molex made removal of the first flipper a breeze Now onto the third and fourth flipper assemblies
#2828 1 day ago
Replacing a bunch of the parts on all four flippers on a Paragon I just picked up. I’m discovering the holes are slightly smaller on all the bushings from PBR, and the screws don’t go through them. Can I just drill them out slightly?? Could this affect pawl placement somehow? Thanks…
#2829 1 day ago
I just did a flipper rebuild on my EBDse, replaced everything but the coil. There was no 'wavy washer' in place prior so there was a bit of play in the coil. I installed a wavy washer with the rebuild and now the coil seems out of alignment just enough to make the flipper stay up when the button is released. a quick tap on the other flipper, or on the side of the machine and it's pulled back down again. What the heck shoudl I do. is it important which direction the 'wave' is facing on the washer or some orientation issue there? I even tried a tighter spring and it helped a bit but the sucker still sticks.
#2830 1 day ago
Quoted from Dakine747:
Turns out, yes I can!
#2831 1 day ago
Replacing a bunch of the parts on all four flippers on a Paragon I just picked up. I’m discovering the holes are slightly smaller on all the bushings from PBR, and the screws don’t go through them. Can I just drill them out slightly?? Could this affect pawl placement somehow? Thanks…[quoted image]
I always just screw right into them. I figure the extra friction will act like a nylon lock nut and prevent the screws coming loose again
#2832 1 day ago
Working on a Paragon flipper rebuild, and replacing the EOS and secondary switches on the two bottom flippers. The replacement switches are wider than the ones they are replacing, and now the mounting screws aren’t long enough - even after removing the little metal piece that sits under the screw heads. What options might I have here? Feedback welcomed. Thank you!
#2833 16 hours ago
Transplant the new blades to the old stack.
#2834 9 hours ago
Thanks! I didn’t realize that the bakelite came apart that easily! Rather than use the old stack, I removed a few of the spacers, and ended up with the exact same switch stack thicknesses without using the old ones. Thankfully there were multiple thin segments rather than larger single segments, so it was simple to do. And the extra length of tubing through the stack was easily trimmable with an exacto knife. Now all is well.
#2835 1 hour ago
Keep all the spacers from switch stacks for the next time you may need them.
#2836 1 hour ago
Quoted from GRUMPY:
Yah, I learned awhile back to never throw any parts away, that could someday be useful.
Men
$ 99.99
Toys/Add-ons
$ 69.99
Toys/Add-ons
$ 109.95
PinSound
Pinball Photos LLC
Decorations
$ 959.00
Flipper parts
$ 69.99
Pinball Shark
Shooter rods
YouBentMyWookie
Other
$ 135.00
Sparky Pinball
Toppers
Bethany Beach, DE
$ 299.95
Pin Stadium Pinball Mods
Led
$ 24.00
Twisted Tokens
Other
$ 5.95
The Pinball Scientist
Protection
Playfields
Detrick Pinball Shop
Playfields
$ 79.00
PinballReplacementParts
Other
$ 37.50
Pino Pinball Mods Shop
Toys/Add-ons
Decorations
KAHR.US Circuits
17,400
Forest Hill, MD
$ 123.00
Toys/Add-ons
$ 45.95
$ 29.95
PinSound
2,950
Emigsville, PA
Precision Pinball prod.
Flipper parts
$ 649.95
Led
$ 52.99
Pinball Shark
Shooter rods
This page was printed from https://pinside.com/pinball/forum/topic/vids-guide-to-upgradingrebuilding-flippers/page/57 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
