(Topic ID: 18292)
VID's Guide to Upgrading/Rebuilding Flippers
By vid1900
9 years ago
  • 2,684 posts
  • 451 Pinsiders participating
  • Latest reply 2 days ago by Karthag
  • Topic is favorited by 1,240 Pinsiders
Revised flipper wiring.pdf (PDF preview)
15 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 2684 posts in this topic. You are on page 54 of 54.
#2651 4 months ago
I don't know of any performance benefits from parallel coils. The EOS switch last longer because of a spark arrestor cap, so this would enhance performance between service calls. But that's about it, no magic here. Return spring design will make more of a difference then replacement of the coil.
#2652 4 months ago
Quoted from GRUMPY:
So, Williams' marketing hype. I suppose the claim would be that since both coils are in circuit for hold circuit, you're heating up the primary coil too, so that it's not going to be as cool for the next power stroke. Hence the marketing line of "more zip for the flip" I suppose.
These aren't on location so any EOS replacements (never needed one at this point after a flipper rebuild's done....) are done here by me anyway.
Curiosity satisfied.
#2653 3 months ago
Quoted from chuckwurt:
Great post. I just had the same issue on a rebuild I did with WPC flippers. Wasn’t the suppliers fault, I grabbed one from my bin that was too short, but same issue.
Would this ever cause a flipper to stick?
#2654 3 months ago
Quoted from zhu808:
Bad plungers stick.
Swollen coils stick.
Mushroomed plunger ends and worn coil stops stick.
#2655 3 months ago
Wrong size flipper bushings will stick from misalignment
#2656 3 months ago
Quoted from vid1900:
How about old, tarnished EOS switches? I operated the mechanism by hand and it's moving perfectly.
#2657 3 months ago
Quoted from zhu808:
Easy enough to loosen and move it out of the way to test the theory.
DONT hold the flipper button, just flip and see if she sticks.
#2658 3 months ago
Hello All:
Finishing a Williams 1950 "Lucky Inning". The flippers are controlled as one with a flat bar connecting both flippers and only one coil to draw the assembly in. Question I have is that the flippers work fine but there is no "umph" to them. They barely push the ball up the playfield. The travel distance for the flippers is near nothing. Any way to improve this? I have replaced all the worn parts. The only thing left would be the coil. I have adjusted the switch which powers the coil but with no real difference.
Suggestions?
Mike
PXL_20210430_154911224 (resized).jpgPXL_20210430_154915351 (resized).jpgPXL_20210430_154916815 (resized).jpgPXL_20210430_154919133 (resized).jpg
#2659 3 months ago
It looks like the coil plunger and the link to the other flipper are mixed up.
Also, you are missing the phenolic link between the coil plunger and flipper bellcrank.
#2660 3 months ago
Are you sure it's the right coil? That wrapping doesn't look anything like what's on my '48 williams.
#2661 3 months ago
Quoted from electricsquirrel:
Sorry The pics I added were teardown pics as I was working through the game. I didn't take any pics of the assembled section but these pics are of another collector's machine with the same layout as mine. I copied that and used the pics I had. So what do you think I am missing? Can you provide pics?
Mike
59077da8746dbd6b2f3739d764dc8cd95a4c416b.jpeg (resized).jpgfc625d08d890947d949d9be25f34fda825162a1c (resized).jpg
#2662 3 months ago
Quoted from zacaj:
I am not sure but I assume that it is correct as the above pics of another machine has the same wrapper color. I know that doesn't mean jack but I don't have a schematic for the game. any help out there from other collectors? I have A-26-1100 on this coil,
Mike
#2663 3 months ago
Quoted from packie1:
Mike
I'm not sure what coil is correct. Williams used different numbering back then. But PBR probably has a schematic, or may even be able to just tell you what the correct coil is if you want to confirm
#2664 3 months ago
Sorry. the pictures were misleading.
#2665 3 months ago
Hello All:
Suggestions?
Mike
Williams was using "Impulse" flipper design at the time. This makes for some pretty weak flips over time. Years ago, I converted a similar machine from impulse flippers to conventional flippers. What a difference that made! There is a thread or two here on pinside detailing the conversion to conventional flippers.
#2666 3 months ago
following
#2667 3 months ago
Yep - she does. I have a new switch in the mail. Should be here any minute now.
#2668 3 months ago
Quoted from KenLayton:
Thanks I will look for it. In the meantime, I did contact PBR and confirmed that the machine has the wrong coil. It is supposed to be a W-27. They are sending substitute A27-850. This should help as I read that old Williams coils use code to identify bobbin and number of windings. Biggest thing here was the windings. The current coil has 1100 windings and the new will be 850. I will try that first and if the "umph" is back great! If not I will go the re-fit route.
Thanks all for your help.
Mike
1 month later
#2669 65 days ago
Has anyone ever stuck a fliptronic mech in an older Data East game (with the conical spring) instead of rebuilding, then just moved the existing coil in and removed the EOS for a rainy day? I recently bought a reimport DE Robocop and the flippers are wrecked... wondering if it's worth just replacing the mech completely with the superior design instead of rebuilding it piece by piece.
#2670 52 days ago
vid1900 I love these guides.
Have I missed it? Was there ever a guide to rebuilding Alvin G flipper mechs? It's tricky to source some parts which has always stumped me.
Flipper shaft Bushign: https://www.pinballspareparts.com.au/fsb-001.html
Crank: https://www.pinballspareparts.com.au/agflipper.html
Crank: https://www.pinballspareparts.com.au/agflipper1.html
Bats: https://www.pinballspareparts.com.au/bulk-items/ag-flipperbaty.html
But I've never found a replacement for the bushing between the crank and the link.
Just give up and replace all of it with a williams mech?
#2671 52 days ago
Yes, I posted about a conversion to complete Williams system 11 flipper assemblies:
https://pinside.com/pinball/forum/topic/alvin-g-flipper-and-sling-assembly-replacements#post-6270619
I did it to a Pistol Poker and they fit and worked great. I used the original Alvin G flipper coil instead of a Williams coil.
4 weeks later
#2672 23 days ago
This is the correct installation of the Coil; Diodes safely away from the Coil Stop. It matters, do it right.
Some Coils were installed backwards at the factory, so you may have to pull a little slack wire from the harnesses to reach the proper position. Don't worry if you have to clip a few nylon Zip Ties to produce the slack you need.
If there is a little plastic nipple on the coil, you can cut it off, or cut a little notch in the coil bracket with a Rat Tail File or Dremel.
So this may be a complete newbie question, but do I need to change the wiring when connecting back to the game, does turning the coil around make the plunger want to go in the opposite direction?
#2673 23 days ago
Quoted from rmillman:
No. Coil only pulls in one direction.
It has to be identical no matter which end of the coil is up or down. Keep wires in the same spots no matter what.
#2674 23 days ago
No and Infact many people flip them on purpose to move the lugs away from the stops.
#2675 4 days ago
Before I dive too deep, could someone let me know if I can use this guide to fully replace and upgrade Data East Secret Service solid state flippers to Fliptronic?
I've been dogged with a bad upper flipper problem I cant seem to fix and will just totally replace, but wondered about upgrading? I'm kind of a noob, but pretty confident, but also realizing that Data East machines are kind of oddballs. So will this fliptronic full replace just work with Data East boards and electornics? Thx
#2676 3 days ago
Secret Service would be rebuilt similar to a williams system 11 flipper - it's not a solid state flipper on that game. That started with Robocop.
#2677 3 days ago
Quoted from slochar:
Thanks slochar but if I want to upgrade to something more "snappy" as Vid1900 suggests can I do the conversion to fliptronic or something newer or will there be problems with the boards, voltage, and/or electronics? Seems like if it fits on the machine then it should be ok, reading through the details here.
#2678 3 days ago
The upgrade to WPC style flipper mechs on a system 11 is replacing the standard conical spring that sits around the plunger and pushes the the flipper back to rest when not activated, with the WPC style return spring (and associated arm extension on the flipper pawl) that pulls the flipper back to rest after flipping.
The WPC style feels snappier because it doesn't induce any drag on the coil plunger, and especially over time since it doesn't wear into the plunger or link.
Upgrading to WPC style is purely mechanical, and in no way effects the electronics of the game (assuming the flipper pawl extension still makes appropriate contact with the eos switch)
I just did this to a Taxi I picked up a little while ago. Simple and effective. Literally changing the spring style and adding the arm to hang it from.
#2679 3 days ago
Converting to WMS "fliptronic" is a whhhoooolllleeeeee different ballgame however, as you would be adding circuitry to the game that wasn't engineered from the start to have it.
Is it possible? I guess anything is possible, but that's way outside of my pay-grade...
#2680 3 days ago
Quoted from Grandnational007:
Yes, this is the one I am doing, and not Fliptronic (which I see now have a driver board and are a whole different thing), thanks for clarifying Grandnational007. I think I got caught up in the additional change of serial to parallel coils, which seems like it can also just be done as well in a system 11 Secret Service without any worry.
#2681 2 days ago
Quoted from L_satan:
Vid,
Will you do an addition about Gottlieb 80-80B flippers?
Yes.
Next time I rebuild one for a client, I'll make up a new section of the guide.
I'm about to rebuild the flippers on an 80B, without the MA988 or MA989 conversion (see http://www.pbresource.com/rebuildk/gtb-ma988MA989.jpg).
Is there anything special I should keep in mind, or is it pretty straight forward? I'm using one of Steve Young's kits.
#2682 2 days ago
Quoted from Karthag:
Secret Service is a Data East game, and not a system 11 (Bally/Williams) game, though there were, shall we call them, certain liberties taken by DE, so there are many things that are *cough *cough "coincidentally" similar, and thus, compatible.
#2683 2 days ago
The main reason people upgrade to some other geometry is because some of the parts are really expensive.
The stock flippers rebuilt with proper parts are fine. If you have 80 games yeah, upgrade to something to only have one type of kit for all the games, or if there's some other reason (bally linear flippers are terrible and aren't built for anything other than lazy operator longevity).
#2684 2 days ago
yeah, Im aware its not a "real" system 11, and that's what I was alluding to in saying DE are 'oddballs' in that sometimes online (here and elsewhere) they get lumped in with System 11 and other times there is a distinction. Which makes sense. It can be hard for someone new in the hobby to figure out the specifics, especially when buying parts or trying to do repairs. So im grateful for everyone's help!
