(Topic ID: 18292)
VID's Guide to Upgrading/Rebuilding Flippers
By vid1900
11 years ago
  • 2,887 posts
  • 488 Pinsiders participating
  • Latest reply 7 days ago by cnordquist
  • Topic is favorited by 1,370 Pinsiders
15 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 2,887 posts in this topic. You are on page 43 of 58.
#2101 5 years ago
Quoted from sohchx:
Does anyone happen to have a parts list for rebuilding this Flipper Power Supply??
https://ksarcade.net/williams-flipper-power-supply-system-9-11-c-9939.html
What game?
The schematic will show the needed parts, usually on the Power Wiring page of the manual
#2102 5 years ago
I am still a true beginner here. Any help greatly appreciated. My WW left flipper has no strength when activated. The flippers doesnt separate the eos really by the coil. It moves ok by hand. What should me next steps be?
20180819_150857 (resized).jpg20180819_150857 (resized).jpg20180819_150947 (resized).jpg20180819_150947 (resized).jpg20180819_150958 (resized).jpg20180819_150958 (resized).jpg
#2103 5 years ago
I'm getting ready to rebuild flippers on Pinbot that I own. I'll be keeping with current coil set up of FL 23\600 30/2600 50V. I'm replacing coil stop, plunger assembly, return spring, and switches. Right now there is a capacitor across EOS switch and coil and it was my understanding that they were only used on upgraded flipper coils that began with F-14. Should I replace during rebuild or eliminate?
#2104 5 years ago
Quoted from pinned_1104:
I always replace them.
#2105 5 years ago
Quoted from vid1900:
System 11 owners update part 2:
You will note that your new "Fliptronic" arms have spring tabs on them. Never again will they suffer with conical springs.
just bought a rebuild kit from PBL and unfortunately it does not have a spring tab on them.
#2106 5 years ago
Quoted from hisokajp:
It still shows them on the picture:
They probably just mis-packed the order. Give them a call and Terri will send you them the same day.
https://www.pinballlife.com/index.php?p=product&id=983&parent=172
#2107 5 years ago
Quoted from TBatti:
That EOS switch looks terrible.
File it to clean metal and set it so when the coil is plunged, you have an 1/8" gap.
(The EOS looks like it's getting thin anyway, if it were mine, I'd rebuild the entire flipper, get rid of that compression spring, replace EOS with fresh...)
Your cab switch looks pretty close to EOL, so you might replace that too.
The reasoning is that you've got a $2k machine, it makes sense to put $40 into it and make the game play better than new.
#2108 5 years ago
Some Sorcerers and Space Shuttles had caps across the EOS, so Williams was experimenting on the cap idea even before it became standard.
#2109 5 years ago
I ordered the kit for FH, the one with the cap:
https://www.pinballlife.com/index.php?p=product&id=980
None on those :S
#2110 5 years ago
None on those :S
That's the wrong kit.
No matter what Williams game you have, if you see conical springs, you know you know you are on the wrong page.
#2111 5 years ago
Thank you. Get rid of compression spring and replace it with what?
#2112 5 years ago
Terry has it listed as funhouse.
I wonder if it's just a recycled photo that's incorrect.
#2113 5 years ago
Quoted from pinballinreno:
You don't necessarily want the "right" kit for your game.
You want to upgrade to the ultimate flipper kit with the extension springs.
Read the first page of this guide to see why.
#2114 5 years ago
Ah, I see what you are saying.
Throw away the anemic conical spring and modernize with the newer, side pull spring setup for much faster flipper response.
#2115 5 years ago
i guess it will do for now, maybe worth putting a clear "buy fliptronic rebuild kit" with additional cap on the side (for dummies like me) in your pinned post thanks!
#2116 5 years ago
Vid, any idea what the proper stroke length (tip to tip) of a system 6/7 flipper should be? I thought I had fully rebuilt my Alien Poker but then I played the one at pinburgh and they were much shallower. Wondering if I'm missing something or if they had done that on purpose for difficulty.
#2117 5 years ago
All the flippers at pinburgh are setup shallow. The machines are intentionally set up difficult so don’t compare your machines to them.
#2118 5 years ago
Quoted from Black_Knight:
So they actually built in longer plungers just for that?
#2119 5 years ago
Thicker coil stops do the trick too.
An even easier thing to do is to setup the flippers flatter, or pointing down more. That would make them act like they don’t have the same range and you probably wouldn’t notice they were lower in that environment.
#2120 5 years ago
These have the built in coil stops by default, unless papa has done the vid mod. And they seemed to be oriented the same. Just half an inch less throw
#2121 5 years ago
That's what the entire 1st page of this thread is about.
NOT buying the kit made for your game, but instead buying the ultimate kit with the extension springs.
#2122 5 years ago
Thank you. I filed it down as a temp fix. I noticed one wore has been disconnected. I cannot tell from the manual wher either goes. If I touch it to the right side of the assembly the flipper kicks the other 2 spots or does not move very well at all. Can I do any damage by soldering it in the wrong spot?
#2123 5 years ago
Quoted from TBatti:
One side of the EOS Switch connects to the center terminal of the coil.
The other side of the switch connects to the outside terminal of the coil that has the NON BANDED leg of the diode.
#2124 5 years ago
Thanks Vid, I just rebuilt the flippers on my DE Time Machine and they are super crisp, and the ball flies off them. I do need to go back and readjust my EOS switch, as it seemed that when I was getting the 1/8" EOS gap, I was getting very little positive contact at the closed state.
But my question is about one of my flippers refusing to stay in position. The right flipper, within a few games as crept up clockwise. I have it tightened up so hard I am worried about breaking my allen key. Any ideas ? It is almost like the momentum of the flip is moving it up. Maybe if I redo the EOS gap it will help, or maybe I should take the flipper off and rough up the shaft where it is attached to the pawl mechanism ?
Anyway thanks again for a source of advice and info.
#2125 5 years ago
Quoted from jaybeedee:
Start with new flippers, because old games could have anything installed in them.
then make sure that, without flipper shaft installed, that the tension bolt can thread all the way into the pawl (sometimes there is junk in the threads).
#2126 5 years ago
Thanks Vid
I'll check the tension bolt. the flippers are original (even got the original Time Generator decal on them) and the right one was working well before.
#2127 5 years ago
Thanks Vid
I have had some success sanding the flipper bat shafts with 80 grit sandpaper so that they are rough instead of polished.
This can make them grip a little better. And of course blue loctite on the allen screw.
It also helps if the allen wrench is new or ground down to a new area so that it fits as tight into the screwhead socket as it can.
#2128 5 years ago
Cheers Vid, I took it off and unscrewed the bolt right out, cleaned and threaded right in then started again and now it is locking properly.
So there's a couple of other things that are quite different since I rebuilt and I don't know if it is adjustments, or just differences in sizes between the original and the kit.
The backhand shots to the ramps used to be very reliable shots. Now they just don't seem to be achievable and my head hurts from trying to work out the physics! Do you think it would be different size in the coil stop limiting the rotation, or the EOS opening too late and the power staying strong through out the stroke ?
Also, I used to get the occasional airball off the posts on the playfield, but now the ball is going up the ramps and sometimes leaping the side of the ramp - I had one ball jump the right ramp and get stuck above the ramp plastic and under the glass.
#2129 5 years ago
Different or new coil stops affect the flipper bat travel
Adjust your flipper angles to where you think the game plays best or at least intended by the designers.
Increase your playfield pitch to slow the game down as needed.
#2130 5 years ago
It's probably just that your shot-timing is now off.
You had gotten used to the old one, now the slop free rebuild is "different"
You got used to letting the cradled ball roll back 4 milliseconds, then firing to backhand. With no slop, it might now be 1 millisecond.
#2131 5 years ago
Hi Vid, I’ve been measuring the resistance on the flipper coils of some pins I picked up recently. I’ve read that it’s generally recommended to replace a coil when it’s below 2.5 ohms. I noticed most flipper coils read 1.2-1.8 ohms while connected but read 27 ohms or more when disconnected. Some of the other types of coils under the playfield & in the relays will read 5 or more ohms while still connected.
My question is, do I need to disconnect the flipper coils each time I test them or is there a way to avoid having to do that?
#2132 5 years ago
Quoted from Pintor:
As your own experience has shown, you DO get different readings on a coil when it is still connected to the rest of the circuit.
Do you ALWAYS have to disconnect a coil to test it? No.....
As you work on more games, you get a **feel** for what a coil should read, even in circuit.
If one pop coil reads .2 and all the others 3.6, you know you have a problem.
So if you saw a .2 coil, you would certainly unsolder that coil and test again.
So if out of the circuit, you still have .2 ohms, you snip one leg of the coil's diode and test again.
If the coil now reads normally, you only have a bad diode (and a 2 cent fix).
If the coil still reads .2 ohms, even with the diode snipped out of the circuit, it's internally shorted - dead.
#2133 5 years ago
My Tom has a flipper that stays up for a fraction of a second after i press the button. The flipper were both rebuilt a few months ago and weren't doing that after rebuild. The game doesn't get played much at all, so it maybe has 40-50 plays since rebuild.
#2134 5 years ago
Quoted from Goalie:
Lift up on the flipper bat, there should be a credit card's thickness of vertical play - if not loosen the pawl and re-tighten with a credit card as a spacer.
The coil stop might be not square to the plunger. Loosen the stop, and REALLY press it into the coil as you tighten the mounting bolts.
The coil stop might be magnetized. Pull it out and see if it can pick up a small screw.
Check the plunger the same way.
Check that the return spring is not touching any wiring.
Check that the coil sleeve does not have any crud in it.
#2135 5 years ago
As you own experience has shown, you DO get different readings on a coil when it is still connected to the rest of the circuit.
Awesome, That'll save me a lot of soldering. Thanks Vid!!
#2136 5 years ago
Hey @vid1900, I apologize if this has been mentioned before, I had trouble searching for it. This may not matter at all and I'm getting way too detail oriented. I'm not sure if there is any actual polarity involved here.
In your early Bally tutorial, you demonstrate the reverse of the coil direction, and you use this photo:
58d52836c6c825a09d2388f4d6bc3290f4fa8ec2.jpg58d52836c6c825a09d2388f4d6bc3290f4fa8ec2.jpg
Upon re-assembly in my restoration, I'm looking at this photo I took of the original wiring of the flipper, as you can see here:
I've reversed the coil orientation as you suggest. This was a NOS assembly, so Bally could easily have had it wired it slightly differently, though it did work prior to teardown
If I am reading this right, your two lugs on the EOS switch are attached to the middle and "bottom" lug of the coil in the photo. If you reverse the coil orientation on my photo, you would also be attaching the two lugs on the EOS to the middle and "bottom" lug, but the switch lugs would be connected the reverse of your coil lugs. Does that matter in any way?
#2137 5 years ago
^ The switch has no polarity.
Everything you do, MUST line up with the diode(s) on your flipper.
Up, down, bottom - don't worry about orientation, just worry about putting the wires back on the lugs using the diodes as your guide.
#2138 5 years ago
Forgive me, but that would require that I know how to use the diodes as a guide.
It sounds like as long as the colors go back to the sides they were originally on, we are good, right? So in my photo, green stays on the same lug it was on before, and brown stays on the same lug (though the brown ones are interchangeable because the switch has no polarity). Right?
#2139 5 years ago
Quoted from jsa:
correct.
If you mix it up, you will know instantly when you blow the under playfield fuse, lol
#2140 5 years ago
Question about flipper coil stop sizes vs flipper travel and use for right games.
Looking at PBL site shows 4 different coil stops for Williams.
Looking for info on what stop is what size and amount of flipper travel.
#A-8143 (Stop size is ??) = EM games and SS games from 1969 to 1979 ??
#A-10821 (Stop core size 6mm or 0.236) = 1980 to 1987 ??
#A-12111 (stop core size is 7 mm or 0.275) = Used on Williams/Bally games from 02/1988 to 04/1993.
#A-12390 (stop size is 8mm or 0.314) = Used on all Williams/Bally games from 08/1993 to 06/1999.
I'm assuming A-12390 has the longest stop so gives it the shortest flipper travel.
I am upgrading several older Williams system 4 to 7 games.
Ex: Gorgar, you would use stop #???? to keep original flipper travel. Or Black Knight, What stop should I use.
#2141 5 years ago
Quoted from arcademojo:
Looking at PBL site shows 4 different coil stops.
#A-10821 (Stop size is ??) = Laser Cue, Space Shuttle (some machines, but not all), Sorcerer, Comet, High Speed, Grand Lizard, Road Kings, Pinbot, Millionaire, F-14 Tomcat, Fire!, Fire! Champagne Edition, Big Guns, Space Station
#A-12111 (stop size is ??) = Used on Williams/Bally games from 02/1988 to 04/1993.
#A-12390 (stop size is ??) = Used on all Williams/Bally games from 08/1993 to 06/1999.
I'm assuming A-12390 has the longest stop so gives it the shortest flipper travel. What is the different sizes of A-12111 and A-10821?
Ex: Black Knight you would use stop #???? to keep original flipper travel.
PBR lists heights for the different stops on the detailed breakdowns of the flipper rebuild kits. eg. http://www.pbresource.com/KT-WFLIP05.html
A10821 protrudes 0.33" into sleeve
A12111 protrudes 0.37" into sleeve
A12390 protrudes 0.42" into sleeve
There's some other notes about flipper mechs around that era: http://www.pbresource.com/rebuildkit.html#baseplate
#2142 5 years ago
Quoted from ajfclark:
Having investigated this recently, either I'm measuring incorrectly or these measurements are completely wrong. I tried every measurement I could think of and none matched up.
The one actually useful measurement though, I think, is the distance from the top of the stop (what the plunger rests against when engaged) and the near side of the vertical plate (what the coil rests against). This sounds like the dame thing pbr says, but..
Measuring this on some A-12111s (assuming I was sent the right part...), that measurement is 0.28".
The measurement on a pinball life repro system 7 base plate with the built in stop is 0.246". The height of the used plate in my black knight (no cupping that I can see) is 0.25".
Also important is the length of the plunger, which I wish I had info on, but I can't even trust stores to send me the right plunger matching their picture, let alone be sure they're reproduced matching original specs...
#2143 5 years ago
A comparison from PBR and Marco.
PBR
Marco
A-10821 Core height from bracket face is 6 mm or 0.236”
A-12111 Core height from bracket face is 7 mm or 0.275”
A-12390 Core height from bracket face is 8 mm or 0.314”
#2144 5 years ago
Quoted from zacaj:
I just went and got some calipers out and I concur. Those measurements don't make sense as written. From the back of the bracket to the tip of the coil they do line up though. eg.
A-10821:
A-12390:
Unfortunately I don't have an A-12111 on hand.
#2145 5 years ago
PBR
Marco
A-8143 Core height from bracket face is ? mm or ???
A10821 Core height from bracket face is 6 mm or 0.236”
A12111 Core height from bracket face is 7 mm or 0.275”
A12390 Core height from bracket face is 8 mm or 0.314”
The A-10821 I have (from PBR) is closer to .250" or 6.35mm. Being a 1/4" makes more sense to me as these things were made to an imperial measure, not metric.
The A-12390 I have is closer to .330" or 8.5mm, also shipped from PBR. I don't work with imperial stuff enough to know if .330" in close to a standard size? 21/64"?
I do not have a A-12111 here to measure unfortunately.
The bracket on the short stop is ~0.08" thick,the tall stop is marginally thicker ~0.09".
0.25 (short stop) + 0.08 (thinner bracket) = 0.33
0.33 (long stop) + 0.09 (thicker bracket) = 0.42
Those numbers line up with PBRs, but from the back of the bracket to the stop, not protrusion into sleeve.
#2146 5 years ago
double post
#2147 5 years ago
Quoted from zacaj:
So, there are different size plungers also? And I'm assuming since different travel lengths each one uses a different link also?
#2148 5 years ago
I'm not sure about earlier williams but Pinball 2000 used different length plungers iirc. The unsurety is what concerns me.
For some reason I couldn't get those to work out for me, but I don't trust them anyway. No guarantee they'll always use the same method of attaching the cores.
#2149 5 years ago
Quoted from zacaj:
I think you are right that only Pinball 2000 used the different size plungers.
So looks like the following for matching games to original flipper travel when converting over to new style.
I would use:
A-10821 coil stop for System 3 to 7
A-12111 coil stop for System 9 to 11
Last concern would be the new vs old style links. I'm guessing I need the old style with use of A-10821 since it has the longest travel.
#2150 5 years ago
Quoted from zacaj:
It's very awkward TBH, and probably not that accurate as you need to get one side of the caliper completely off the riveted butt and the other on the coil stop, so it's not measuring in a direct line between two flat surfaces and any change in the bracket will change the measurement. Better than measuring directly between the coil stop face and the riveted butt though I guess and it probably is good enough to distinguish between unlabelled parts though.
Holding something flat against the coil stop and measuring between that and the bracket seems like a much more sensible idea, less prone to error, and should correlate to measuring the stop before it's fixed to the bracket, etc, etc.
$ 959.00
14,000 (OBO)
$ 123.00
$ 1,319.00
$ 29.00
$ 59.95
pinballmod
$ 59.95
pinballmod
Newcastle, OK
$ 41.99
Lee's Parts
YouBentMyWookie
Hookedonpinball.com
12,500 (OBO)
$ 70.00
Creekside Hideaway, LLC
Pinball Photos LLC
Various Novelties
Pinball Photos LLC
2,500 (OBO)
Vista, CA
$ 69.00
Pinball Pimp
$ 17.00
Metal-Mods
$ 0.00
PinJewels
$ 1,059.00
€ 50.00
Pino Pinball Mods Shop
$ 69.00
Pinball Pimp
€ 160.00
This page was printed from https://pinside.com/pinball/forum/topic/vids-guide-to-upgradingrebuilding-flippers/page/43 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
