(Topic ID: 18292)
VID's Guide to Upgrading/Rebuilding Flippers
By vid1900
11 years ago
  • 2,887 posts
  • 488 Pinsiders participating
  • Latest reply 3 days ago by cnordquist
  • Topic is favorited by 1,370 Pinsiders
15 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 2,887 posts in this topic. You are on page 22 of 58.
#1051 8 years ago
Quoted from mof:
I'm wondering what's going on here. Is the switch too short?
There is probably a little play to move the switch up a little.
The "rubber" boot, was it really rubber? Shrink tubing is usually kind of slippery, rubber kind of sticky.....
#1052 8 years ago
Quoted from chuckwurt:
What happens of i put the coil sleeve in backwards?
The coil works in either direction, so if you put the sleeve in backwards, you flip the coil too.
The flanged part of the sleeve goes around the coil stop.
#1053 8 years ago
Quoted from vid1900:
Or if you don't care about how "stock" it looks, you could do a WPC flipper mech :
https://pinside.com/pinball/forum/topic/vids-guide-to-upgradingrebuilding-flippers/page/3#post-773606
I had read that post before and had Terry make me up a couple. I don't care what it looks like. I wanted a replacement that was snappy and I could get parts to rebuild it if necessary. One question though, is the SFL-19-400/30-750 coil series? This would mean the EOS switch needs to be N.O. right? Thanks.
#1054 8 years ago
Quoted from slgerber:
You need a Normally Closed, High Voltage EOS Switch.
Terry at PL will actually make the entire assembly for you for only $36:
http://www.pinballlife.com/index.php?p=product&id=172
Make sure you email him and tell him you need the SFL 19/400 - 30/750 coil and a high voltage EOS switch, as they are not a standard pull down menu choice.
#1055 8 years ago
Yes I ordered these yesterday. I was asking because of what I read on Marcos site.
http://www.marcospecialties.com/control/keywordsearch?SEARCH_STRING=19-400%2F30-750
#1056 8 years ago
Strange, I'm not sure where they copied all that from.
You want Normally Closed, High Voltage (big silver tungsten contacts), EOS Switch.
#1057 8 years ago
Yeah, that's just straight up WRONG. The hold winding is *bypassed* by the Normally CLOSED EOS as the switch is the Path of Least Resistance. When the coil fires and opens the EOS switch, current is forced through the hold coil, which holds the flipper and also keeps the pull coil from burning out.
#1058 8 years ago
Are you saying that's just shrink tubing on there, and possibly the reason this is happening is that it's old and dry? Try putting new shrink tubing on there and see if the switch stops catching?
-mof
#1059 8 years ago
Usually the pawl has heat shrink tubing on it, so it's slippery.
You can put two layers on it, and bend the switch a little to make it not stick.
If nothing helps, get the proper longer switch.
#1060 8 years ago
I've noticed many Data East games don't use lock nuts on the back side of the flipper plates. Have you seen any negative effects from this? Ironically the only trouble I've had with bushing screws falling out is on Williams games.
#1061 8 years ago
Quoted from Crash:
The threading tolerance was pretty loose with those Williams.
I'd just put the backing nuts on the DE anyway - cheaper than a playfield repair.
Classic Bally coil stops also were threaded poorly and often loosen or strip out completely. Backer nuts or even a plate for those.
#1062 8 years ago
I noticed Data East also uses deeper threaded holes for their coil stops.
#1063 8 years ago
I just ordered Williams coil FL24-600/30-2600 from Marco, but I noticed after checking all the different sites nobody has these except Marco. Is this a hard to find coil? If so is there a replacement? It's on a Laser Cue system 7, 50 volt coils
#1064 8 years ago
I know we have talked about this before, but I am getting a bounce to my flipper after each time I engage and it seems to be costing me some power. I have a new eos, bat, bushing, coil, and coil stop. Oh yeah and a new plunger. It's an early stern SS. Any way to eliminate that bounce? All three other flippers don't bounce at all.
#1065 8 years ago
Thank you for the help!! Great instructions.
#1066 8 years ago
So it's about time to rebuild my flippers on JD as they all seem a little weak, especially the lower right as that ones seems to have a slight delay. Anyway, 4 flippers on this bad boy and I'm kinda dreading getting all 4 rebuilt and lined up properly. The upper flippers are also a lot shorter and I do not see a rebuild kit for these upper flippers on Pinball Life just a kit for the lower flippers? The upper flippers also do not have the pin holes to align the flipper so what is the best way to align the upper flippers? Any of you JD owners out there have some good tips before I dig into this project? With new flippers this game is gonna be so much better but just want to do it right. Thanks all.
#1067 8 years ago
Rebuilding my fire! Flippers. My coil has this tab that will not let me install the coil as you suggested. Should I just get it the way it came factory, or is it that big of a deal that I need a new could that I can flip around per your instructions?
#1068 8 years ago
It's better to put it the other way (reduces impact on the diodes/lugs), but not a huge issue since they're not getting beat on as much in a home environment. You could also just cut off the tab.
#1069 8 years ago
Quoted from Lethal_Inc:
The holes aren't always that accurate anyways. Just line the flipper bat up with the guide that feeds the ball to it. The ball should transition smoothly to the flipper w/o a hop.
#1070 8 years ago
Maybe use a straight edge that extends past the guide lanes to the flippers then right?
#1071 8 years ago
Quoted from terryb:
Cool thanks. I just left it how they were.
#1072 8 years ago
Recently did my Big Guns flips and drilled/filed the plate opposite the coil stop to let the tab fit and it worked like a charm.
#1073 8 years ago
Use a Dremel or rat-tail file and make a quick notch in the coil bracket.
If you have neither, just cut the nylon pin off.
#1074 8 years ago
Vid- question regarding system 11 flippers and the conical spring. I just picked up a Taxi with the modern return spring but it is hooked around the zip tie holding resistor. Is this right / wrong / good / bad?
Assuming it is ideal to drill the small hole and make it permanent. But is this better than conical spring? I'm a little nervous to try to drill (I'm still pretty new to all this). Do I just want to use a metal-specific bit and clamp the piece down in a vice? Any specific bit that works?
#1075 8 years ago
Quoted from Elicash:
That is a lazy way to do it, but it's better than nothing.
It probably is putting a little more tension on the spring, by stretching it farther; so you may get just a little less flipper power.
Yes, conical springs break and scar the plunger.
The bracket metal is very soft.
Any sharp drill bit will bore through it in seconds.
Don't slip and drill through the coil!
#1076 8 years ago
Replacing the flipper bushings as part of a rebuild. The three screws that hold the bushing in are TIGHT. Broke one... how normal is this?
T2 machine with a lot of miles on it.
#1077 8 years ago
Not normal, too tight obviously. Use thread locker, blue 245, on all 3 screws and tighten snug. In the process of rebuilding my flippers on JD right now and the flipper bushing can easily be replaced when you remove the whole assembly from the game and rebuild/replace parts right in front of you. I find it hardest to correctly align the flipper bats once your done, so damn touchy.
#1078 8 years ago
Quoted from kilmarnock1350:
Not normal.
Somebody probably used Loctite on the screws.
#1079 8 years ago
So, uh, does this need a rebuild?
Seriously though, how do you determine if this type of crank needs to be replaced (Harlem Globetrotters)? They look ok without knowing what to look for.
#1080 8 years ago
Quoted from aobrien5:
Kinda like when you buy a used car, the first thing you do is change the oil......many collectors rebuild the flippers before they do anything else.
You can measure the length of the plunger and the coil stop with a pair of calipers. (somewhere I posted many of the lengths when new, but I can't find it).
You can manually grab the flipper bat and check for slop or play in the link.
On an old Bally, usually the fiber links have a ton of play because the holes have elongated. The cranks will outlast 5 sets of links.
#1081 8 years ago
Dear Vid,
I'm installing new flipper assemblies on a 1982 Williams Defender.
I ran into a problem I've come across several times. You are a big proponent of installing all new parts.
Sometimes, I CANNOT get the new sleeves into the old solenoids. Any idea why? When I hold the old and new one end to end touching, I swear I see the newer one is 1/4 of a human hair thicker...
I'm spending 20 minutes cleaning up the old sleeve and re-installing it.
thanks,
mof
#1082 8 years ago
I've got a box of 200 those sleeves, so I can try a few.
Naturally there is some variation and I can usually find a fit in just a few tries.
On the road I obviously can't take 200 sleeves with me, so I have a drill bit in my kit that **just** barely reams out the solenoids so any sleeve slides right in.
#1083 8 years ago
What is the replacement to a PinBot AE-23-800-04 for the newer Williams parallel coil?
I'm guessing FL-11630
#1084 8 years ago
Quoted from Plumonium:
The factory flipper coil was actually a FL- 23/600-30/2600 so the Parallel coil would be FL-11630
https://pinside.com/pinball/forum/topic/vids-guide-to-upgradingrebuilding-flippers/page/2#post-453690
#1085 8 years ago
Thanks Vids! What an idiot I am, I did not read the correct schematic... You are right! thanks buddy
#1086 8 years ago
Not sure why, but might bottom right flipper is a lot weaker than the bottom left. Same coil, all new parts. Any ideas what my issue is?
#1087 8 years ago
I'll guess EOS switch.
Using a set of allagator clips, jumper the EOS switch closed.
Don't hold the flipper too long, just test if it now has full strength.
#1088 8 years ago
Okay not sure how to do this. I put one end of the aligator clip on what and the other end on what? Game on and start a game first?
#1089 8 years ago
See how the EOS switch has 2 leaves that make contact with each other?
Using the clips, connect one leaf to the other leaf.
Make sure nothing else is shorting to the leaves, and turn the game on.
#1090 8 years ago
Okay. I did this, turned the game on, nothing happened.
#1091 8 years ago
Move the left hand clip upwards (behind the tungsten contact point), otherwise it is going to get whacked by the pawl arm.
Start a game, see if the flipper is strong.
#1092 8 years ago
It's hard to tell from a pic, but that 1 coil wire going to the EOS switch has a sharp kink in it. Could it be open there by chance?
#1093 8 years ago
That does look like a kink, but nothing there actually no pinch in the wire. I moved the left clip up next to the contact. Started a game, nothing. I shouldn't press the button right? The flipper should engage in its own right?
#1094 8 years ago
Start a game, press the flipper button - the flipper should kick like a mule
#1095 8 years ago
Okay yeah. Strong as shit when I do that.
#1096 8 years ago
Strong as shit
Got to start eating more fruits man...
#1097 8 years ago
OK, so now you KNOW that the EOS switch is maladjusted.
Clean it completely and then tension BOTH leaves so they spring tightly towards each other.
#1098 8 years ago
Okay cool. I'll try that.
#1099 8 years ago
That was it! Nice and strong now. Thanks Vid!
#1100 8 years ago
so my TZ upper left flipper half flip most time... The EOS close as it should pretty much at the end of the flipper bat rotation, what else could be an issue?
$ 69.00
Pinball Pimp
$ 135.00
Sparky Pinball
$ 69.99
$ 70.00
Creekside Hideaway, LLC
12,000 (OBO)
Wilmington, DE
$ 59.95
pinballmod
€ 160.00
Pino Pinball Mods Shop
€ 50.00
$ 41.99
Lee's Parts
$ 17.00
Metal-Mods
12,500 (OBO)
$ 1,419.00
$ 1,319.00
$ 49.99
$ 69.99
$ 0.00
PinJewels
$ 1,059.00
Various Novelties
Pinball Photos LLC
$ 69.00
Pinball Pimp
14,000 (OBO)
$ 1,159.00
This page was printed from https://pinside.com/pinball/forum/topic/vids-guide-to-upgradingrebuilding-flippers/page/22 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
