Quoted from PinFixin:What would you recommend to fix these enlarged hole?
This is on my future spa on probably the highest stress area on any pinball machine. A mini post bolted through the playfield right in front of the flippers. These things get pummeled quite a bit. I've read that people say Bondo is too soft and to use Qwikwood, and then others say Qwikwood isn't for use on playfields and to use Bondo, and HEP uses Bondo. One of those answers is completely wrong for this application but I don't know which, or if there is something else?
I wanted to fill with something to remove the hole, then drill a hole for a #10 mini post bolt, and either go into a t-nut (preferred) or just a washer and nut underneath. Or would you guys recommending something different?
Pics:
[quoted image][quoted image]
I'm even open to the idea of thinking outside the box and putting a different, newer style post there that would hold up better to the onslaught, but not be any larger in diameter to make the shot more difficult.
I use new doweling pieces.
1) Plug hole with tight dowel. May need supper glue instead of wood glue.
2) Redrill new hole..slightly smaller than mini post.
3) Use dry soap on mini post to rethread wood hole.
4) Finish with mounting hardware.
