Quoted from rdrapeau3171:I didn't scan the decals before I started (of course). They were on a white sheet.
Even white on white will come out grey when you turn up the contrast (or darkness) on the laser printer
Quoted from rdrapeau3171:From what I described that I did, do you think those are fisheyes or just improper technique, weather, humidity?
Usually fisheyes are some sort of contamination, but that looks like zillions of bubbles of trapped gas
Could be a bad batch, two layers were incompatible, too thick application, or could be the clear hardened before the gas could escape
No matter the cause, the fix is the same: expose bubbles by sanding, fill with the next layer of clear
Don't sand through any more decals, carefully hand sand around them to expose any remaining bubbles
