New! Dark mode!
(Topic ID: 33446)
Vid's Guide to Ultimate Playfield Restoration
By vid1900
7 years ago
  • 7,108 posts
  • 666 Pinsiders participating
  • Latest reply 3 days ago by Atari_Daze
  • Topic is favorited by 1,632 Pinsiders
There have been 2,244 images uploaded to this topic. (View topic image gallery).
142 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 7108 posts in this topic. You are on page 142 of 143.
#7051 68 days ago
Those decals are really impressive sethbenjamin! What brand do you use, and do you use the decal solutions? Any issues clearcoating them?
#7052 68 days ago
Quoted from dr_nybble:
I use the decal paper that pops up on Amazon, though I should be shopping from Blick on general principle...
I don’t think brand matters a whole lot when it comes to decal paper, in my experience. I’ve used the “Sunnyscopa” white and clear papers with good results, for playfield repair and for reproduction plastics.
I use the decal solution vid1900 recommends. it’s helpful if you get a wrinkle, though usually a bad wrinkle means making a new decal as the toner flakes off. Still, the setting solution seems to help get the decal to flatten completely. Especially nice for edges, which can sometimes lift a bit and be hard to get to lay just so.
I’ve never had a problem with the clear. Always out decals between clear layers and spray a mist coat first, then a normal coat ~15 minutes later.
#7053 68 days ago
More important when making decals is minding the printer settings. Color adjustments can alter the output significantly. So you want to be consistent about how you adjust those sliders, and not deviate once you find the right combination. My printer has red, blue and yellow adjustment, as well as contrast and saturation. Had to fiddle with them to dmfind rhe right match to the existing paint, somewhat nerve-wracking...
#7054 67 days ago
Quoted from sethbenjamin:
Do you use a laser printer?
#7055 65 days ago
Quoted from Silverstreak02:
Yes, a non-fancy Brother, under $300 on Amazon. I busted it on this job!
#7056 65 days ago
Brothers laser printers are great, though I only have a B/W one. Looking to perhaps get a one for color but those cartridges are expensive!
#7057 65 days ago
Quoted from wayinla:
This one worked great until it wrapped a piece of decal paper around the last drum, that one that gets real hot - it glued the paper to itself! There was absolutely no way to access it - believe me I tried - so I had to slice the paper and grab at it with a hemostat. Not good. So now it seems like there’s a spot where the toner doesn’t bond to the paper.
I guess the lesson here is to only do a few decals at a time, before the printer gets really hot. But really, I wasn’t using it that hard! I need to figure out if the problem is permanent. A replacement printer wouldn’t be the end of the world, though it would be nice to get one that can lay down a truly opaque black, for places involving decals over inserts. (I usually have to double those up.) But the options seem to be ~$250 8.5 x 11 home office printer, ~$3k 11 x 17 medium format printer, or $$$$$$$ professional print shop model.
And yeah, they nail you on the toners. FWIW, I had to run a LOT of test decals while working on this playfield and the toner supply seemed to be holding out pretty well.
#7058 64 days ago
I used to use a color laser, it would jam and could streak. Now I just take all my printing needs to Kinko's. $1 per page color and like 0.15 for B/W.
It's SO much easier. But then again I have one two miles from where I work.
#7059 64 days ago
Drums for brother are fairly inexpensive. I just bought one for my all in one for less than $20
I have a canon lazer for color.
Its pretty accurate. Cost about $140.
Carts are not to bad if you get the discount ones from discount office supplies online.
I make ramp decals and such with it.
#7060 64 days ago
Quoted from Atari_Daze:
Kinkos/fedex won't do any work for me here due to covid concerns.
I cant get them to even bind a manual right now.
#7061 61 days ago
I can’t see making that work efficiently; for something like this I ended up printing a lot of tests before arriving at the final pantone values. I need to be able to print, lay down a test, tweak, try again, repeat.
#7062 59 days ago
Posting this here since no one has heard of this poly ...
Anyone have experience with this water based poly from Crystalac? Looking for something a bit more clear/durable than traditional polys and lacquers. Yes, I'm well aware of auto-clears, but I'm not interested in hearing about the pros and cons of those products, since I won't be using them on my EM games I'm looking to clear due to health reasons and no local clear coat guys in my area...
Originally created for the luthier trade, but their products have branched out:
http://www.crystalac.info/extreme-protection-polyurethane.html
#7063 59 days ago
I have not heard of that one.
I have used Varethane water based urethane for full clear coat and to protect touch ups.
The colors are not as vivid as auto clear, but honestly, it is quick and easy. It is especially good at protecting touch ups on a playfield you are not going to completely clear coat.
It stands up very well and can be easily removed if you go to a full restoration.
I have switched to using the 2k rattle can 2PAC for full playfield clear coats and I like the results.
If you try it out, report back how well it works and if it stands up to abuse.
#7064 57 days ago
Quoted from Dono:
It is polyurethane based , single part. I used a similar product that was for wooden floors. The description , prep and drying times was the same as the one you mentioned.
I used it on my first ever restoration. It tends to yellow a bit with time , at least mine did after 2 years . Not much but it was noticeable. Other than that if you do it properly and apply enough layers you will not have problems regarding protection. If you later have the option to apply 2pac , it can be probably removed with aceton .
#7065 56 days ago
I'm having trouble cleaning the playfield on my Bally Bingo Laguna Beach. Looks like some sort of coating that won't come off. I've tried everything but paint thinner. My guess the motor below the field probably baked it in. The rest of the playing field is taking a lot of elbow grease.
Any ideas?
#7066 56 days ago
Quoted from plumbertim1:
Any ideas?
Looks like maybe what’s left of the original lacquer? Have you tried alcohol on magic eraser? I’d be REALLY careful not to let any solvents touch the areas without that coating, though. It could take the bare artwork right off.
#7067 56 days ago
Any ideas?
Try krud cutter on a rag.
It kills nicotine stains.
#7068 56 days ago
Could it be polyurethane?
I do not think think the early games had any clear, not even laquer.
#7069 56 days ago
Quoted from PinballAir:
Early games used shellac, its yellow.
#7070 54 days ago
Free to good home - though you would have to pick up from my Morris County, NJ address. Been opened a while ago, but are both still liquid
#7071 51 days ago
Who here has recreated/airbrushed wood grain? Would love to add that to my skill set.
#7072 51 days ago
Me too
#7073 51 days ago
Quoted from John_in_NC:
Bueller?..... Bueller??
#7074 51 days ago
That is a HSA restored playfield. I know exactly how to do that. It is all done by airbrushing. You need to airbrush the darker woodgrain lines and then do the lighter tan flesh color on top of it. Your doing the flesh tan color in very light coats so the darker brown paint under it can be seen.
#7075 51 days ago
Lots of youtube videos (not pinball specific) re: recreating woodgrain with airbrush. A combination of techniques is necessary depending on the situation.
#7076 42 days ago
So, increasingly I am finding decals to be the best way to restore worn/missing artwork on playfields, but I am finding that it can be tricky to get truly “solid” blocks of color using a laser printer.
I already own a very good inkjet printer which can make beautiful photographic prints, but the prevailing wisdom from Vid is that inkjets are to be avoided as they are prone to fading over time.
Surely there have been advances in inkjet prints/fixatives/papers in the years since Vid first wrote this guide? I get very good results with laser printed decals, but I could get even better ones using inkjet. Also, doesn’t 2PAC block UV, rendering the issue kind of moot?
Just curious to hear if others are thinking along the same lines.
#7077 42 days ago
Pigment based ink jet prints should last about 100 years. Dye based inks can fade quicker, although I think they last longer if sprayed with fixative.
There are plenty of articles on line.
Note: I used to have a great pigment based photo printer (Epson R2880), but the problem with that one, as well as all of them from what I understand is that they need to be used very often, like once every few days or once per week at minimum so the inks don't dry up and clog the nozzles / print head. The inks are also pretty costly. Note that dye based inks may not be waterproof.
#7078 42 days ago
Look for archival or lightfast ink printers like Epson Ultrachrome.
Like this one: https://epson.com/For-Work/Printers/Large-Format/SureColor-P700-13-Inch-Photo-Printer/p/C11CH38201
#7079 39 days ago
Canon Pro-1000 as well, I think. And the Epson P800 accommodates wider paper, if needed.
#7080 35 days ago
So I have a repro gold PF from CPR which at a big glow of glue? behind one of the insert. I tried cleaning it out with a Qtip and alcohol but it just spread it around. It all stuck and dried out now...
I am not sure how to clean that out without damaging it? I can't imagine the insert needs to be swapped and the whole thing recleared... right?
#7081 35 days ago
Quoted from hisokajp:
Can it be seen from the top?
Just carve away any glue that might cast a shadow on the insert.
Glue globs and errant wood fibers are normal.
#7082 35 days ago
yeah, looks very cloudy and blotchy, with or without light it's pretty visible... it looks better when I put some Naphta on top so I am wondering if I could put a couple drop of clear in the back? or something similar?
I feel if i tried too hard the lens will get worse, i really don't want to have to get the lens swap and PF cleared again...
#7083 35 days ago
I would try carefully removing the glue first.
#7084 34 days ago
try acetone to clean as much as you can ,scrub away the glue with a Dremel or manually, clean with naphtha , Partially fill the bottom with some clear.
#7085 29 days ago
Does anybody have experience with the Planetary Pinball apron decals? I'm thinking about going that route rather than trying to cut my own stencils. Are they an actual waterslide decal, or some sort of vinyl? I should be able to shoot 2PAC (Spraymax) over either, I'd think..
TIA for any input!
#7086 29 days ago
Quoted from PinballBillinFL:
TIA for any input!
Stick on vinyl
#7087 29 days ago
TIA for any input!
I started to restore a TOTAN apron planning to use PPS decals, but up close, they are simply inkjet looking print on sticky vinyl. Not very exciting. I chose a different approach and sand blasted the apron, painted on sunny gold and clearcoated the metal, and then applied laser cut vinyl from Treasure Cove. Looked PERFECT when I was done, way better than it would have with inkjet printed stuff. That said, I had options. You may not depending on what you plan to cover...
#7088 29 days ago
Quoted from Markharris2000:
Thanks to both! My original plan was to cut some stencils using my Silhouette Cameo, but thought this might be a quicker path. I think I'm back to doing my own, and airbrushing the colors.
11
#7089 28 days ago
The Silhouette is really a critical tool for repaint (vs minor touch ups). My before and after - airbrushed everything using Silhouette vinyl stencils.
#7090 28 days ago
Quoted from Boslaw:
[quoted image][quoted image]
#7091 28 days ago
Nice work!
#7092 28 days ago
Thanks. I've learned a ton from this thread and the Silhouette Cameo thread. This was a great playfield to learn and experiment with.
#7093 28 days ago
If i werent slowly backing out of the hobby i would purchase the silouette.
I still dabble in restoring but mostly just use frisket as it is cheaper.
#7094 15 days ago
I just want to comment and say how much of a pain in the ass it is to color-match using Createx paint. It's probably not a drawback inherent to only this brand, but there are too many variables affecting your initial color-matched paint you mixed up. I had my paint change color when it dried which was expected, when it had mineral spirits applied (mimick clearcoat) which was expected, but it also changed color when I added required reducer to use in the airbrush. It's very difficult trying to project that many steps out on how the color will eventually be.
I finally airbrushed 5 of the 6 yellow bands to my liking, I still have to clean up the black edges. And I didn't airbrush the entire band on any of them, I stopped where there was a forgiving breakup of the color, as I only wanted to paint where there was severe planking and to keep as much of the originality as possible. One of the yellow bands looked fine so I left it original.
Are there more user-friendly paints out there that are of the same quality as Createx? I've seen Tamiya brand, but I do not know if that brand suffers the same high-learning curve on mixing.
#7095 15 days ago
I am using Golden High Flow paints.
They have an online colour mixer here: https://www.goldenpaints.com/mixer
The colour mixer is worth the price of admission for me.
Zero problems with paint coming up with masking, dries pretty fast, sprays straight out of the bottle. Not cheap but they are high quality.
#7096 15 days ago
Interesting, going to have to investigate!
#7097 15 days ago
That online color mixer is such a valuable tool. You likely want to make sure your monitor is calibrated to accurate color. Nearly every monitor is set to a color temperature that is too blue, and some monitors don't even have color correction settings. Fortunately I have a colorimeter and a monitor that is color-calibrated, this thing could come in handy. The Golden High Flow paint is priced the same as Createx.
#7098 15 days ago
I use the Nix colour scanner and input RGB
#7099 15 days ago
Quoted from Flipper_McGavin:
That looks great!
#7100 15 days ago
All I use is Createx and its very easy to colour match perfectly. Adding the 4012 to it does not change the colour at all. What actual createx # yellow are you using?
$ 54.99
Van Alstyne, TX
PinSound
