Working on a Firepower pop. Lower left to be specific.
Background:
Discovered that the lower left pop wasn't activating. Didn't do any troubleshooting because when I opened up the playfield, and took the bumper apart, it was apparent that the coil was fried, and the sleeve was melted. So off to Marco for replacements. (Coil, plunger, yoke, etc, and new parts for playfield.) Following the guide, I was able to successfully rebuild it, or so I thought.
Also, this game has a new Kohout Driver Board connected to the original MPU.
Issue and symptoms:
I have 32.X volts across both lugs on the new coil. It is wired correctly, the red wire is consistent across all the other pops and oriented correctly to the diode. (double and triple checked....)
Still not popping, however I do have connectivity from the switch back to the driver board. So I know the switch is making contact.
The Orange Red wire (Pin 3) is showing 4.89 V at the driver board. Other pops show 4.9 to 5.0) When activated, nothing happens and the voltage goes to 20.X, while other pops go to 60.X. (I know not to hold it down for a long time, )
The switch looks original. I know there is a capacitor and a Resistor in line from the two blades that connect when contact it made on the skirt.
The scoring is working correctly.
So now I am at a loss. What other further testing can I do? There is a Green Yellow that traverses the underside of the playfield. Would that voltage help?
Also I am NOT opposed to rebuilding the switch. PITA location wise, but I am getting better each and every time I work on the machine. If the recommendation is to rebuild, what are resistor, capacitor, and diode components as I can't seem to find a BOM for the switches anywhere......
Thanks in advance for any help.
