Quoted from zug1619:Ok...Finally getting around to working on the boards again (I'm super slow). Removing the SCANBE pins is a PIA. I got the hang of it for most but there's usually one on each row that either breaks or just won't come loose...anyway...i got them all finally. Ended up getting new soldering tips, including some more narrow ones, and that helped a bunch.
got a quick question...and i think i know the answer but just curious...again
I accidentally removed the plastic from one of the unused SCANBE sockets...even though Vid said not to bother with
My question is what's the easiest course of action now?
1. Leave it alone, just make sure none of the pins are bent and touching
2. Remove the pins and leave the holes empty...(Pretty sure they dont need a pin in there for the signal to pass thru)
3. Remove the pins and put in new connectors...even though they will never be used
4. Leave the pins in there, and short snip the tips off so they can't ever touch in the future.
Any issues if i do number 4?
What do you think is the best course? Is there another option I'm not thinking of? I know it's really hard to get the pins out after i short snip them (should i need the board for another game, but i don't think i care about that).
Dan the Painter[quoted image]
When I rebuild these boards I replace all the scanbe sockets even if the current machine doesn’t use them. You get a finished board that looks great and if you happen to want to install in a different machine with a different ROM configuration all the sockets are already done. The extra sockets don’t add much cost and it doesn’t take that much more time to do them.
If it isn’t used you don’t have to. For me I want the boards to look as good as they work and prefer the clean look of new sockets and keep the option open for easily using them if needed.
