Quoted from vid1900:So now you have your newly crimped wire.
You can note that the Dual Crimp dies did both the conductor and insulation crimp at the same time. This saves your hand at the end of the day by cutting your crimping in half.
You can also see that the Trifurcon connectors triple the contact area. This is good for a high vibration location like a pinball machine.
You can see that the little bit of conductor sticking out past the crimp, matches the factory made one.
You can also see our locking tab on the bottom - remember the tab goes in the little window when you slip it back in the plastic connector housing.
It's going to take you a hour to redo all those contacts.
Do it while seated, with a nice alcoholic beverage at your side, and some T Rex on your speakers.
T. Rex Jeepster or the Motivator! Will be doing a Xenon playfield as soon as one is available, little nervous about the dishwasher cleaning. Working on updating my boards now, great thread!
