Quoted from vid1900:Here is a great diagram of the board pinout stolen from Tom Callahan.
http://pin-logic.com/
On connector J1 I am missing a blue wire on my Lost World. Does this game not use two blue wires on the powersupply?
Quoted from pacman11:According to this J1 has two blue wires?
That is for Bally KISS pinball.
Quoted from pacman11:On connector J1 I am missing a blue wire on my Lost World. Does this game not use two blue wires on the powersupply?
It's in the schematics. There is only 1 solid blue wire and that J1 connector is only 8 pins total, not 9 pins.
Please take a moment to learn how the wire color codes are marked.
Quoted from pacman11:Oh shit! Thanks I think I bought the wrong power supply too.. I’ve got nine pins on J1
No big deal. Just ignore the extra 9th pin on your board.
Quoted from G-P-E:No big deal. Just ignore the extra 9th pin on your board.
Thanks everything is working except half the GI now.. Looking for a short now..
Turned on Stars and only had GI lights. Took the backglass out and noted the CPU power and test lamps were on solid.
Found the CPU +5volts was 4.2v and which comes from the regulator on the power driver board connected to the +12v which was pulled down to +10v.
After reading this tread, picked up new ESR meter and new replacements for C23 and C24. Meter confirmed both were shot, so replaced them and added the TP1-TP3 jumper, and back in action.
Thanks Vid, wherever you are.
I’m working on a Bally 2518-22 SDB for a friend. He brought over a box of crap and would like me to see what I can do. I have very little experience and knowledge, but I would dive in and try. I’ve been able to get 4 up and running 100% and that feels great. BUT, he has one that locks on ALL coils on power up and blows playfield fuse. It came in that way. I’ve rebuilt J3 and J4 with new pins. Checked tip102 transistors and they measure normal. Thought it might be the U2 chip on the board, it was nasty looking. Pulled another off a parts board and no change. So, what would lock on all coils at power up? All driver board test points are within range.
Thanks for any help.
I know this is old, but it just helped me greatly. Thanks!
Quoted from Ballypalooza:I’m working on a Bally 2518-22 SDB for a friend. He brought over a box of crap and would like me to see what I can do. I have very little experience and knowledge, but I would dive in and try. I’ve been able to get 4 up and running 100% and that feels great. BUT, he has one that locks on ALL coils on power up and blows playfield fuse. It came in that way. I’ve rebuilt J3 and J4 with new pins. Checked tip102 transistors and they measure normal. Thought it might be the U2 chip on the board, it was nasty looking. Pulled another off a parts board and no change. So, what would lock on all coils at power up? All driver board test points are within range.
Post some good pics of both sides of the board
Could be a solder bridge
Hey Vid, can you give any advice or maybe a guide for Stern Sound boards? I've got a Catacomb that screeches a single sound bit god awfully loud on power up.
Quoted from vid1900:C24 is part of the 5v circuit, bottom right of big heatsink.
It is originally an electrolytic style cap, and is often replaced with a much better Tantalum style.
Is it ok to use a 2.2uf instead of the 2uf for C24?
-Pat
Does anybody know if there is a thread where the relevant part numbers are listed for doing complete bullet proofing work on various boards? I can buy kits from Big Daddy, and appreciate that they have those ready to go, but if you have to do multiples that option gets pretty expensive.
Just wondering if this info is compiled somewhere already before I dive into a big research project…
Quoted from sethbenjamin:Does anybody know if there is a thread where the relevant part numbers are listed for doing complete bullet proofing work on various boards? I can buy kits from Big Daddy, and appreciate that they have those ready to go, but if you have to do multiples that option gets pretty expensive.
Big Daddy lists the actual parts that are included in the kits on his site -
Quoted from pinzrfun:Big Daddy lists the actual parts that are included in the kits on his site -
Ooh, I missed that! Thanks.
I'm rebuilding the bridge rectifier board for my Paragon. Pinball life has these 35amp/600v bridge rectifiers, will these work? I assumed they would I just wanted to check first.
https://www.pinballlife.com/bridge-rectifier-35amp-600volt.html
Quoted from Foxxstone_80:I'm rebuilding the bridge rectifier board for my Paragon. Pinball life has these 35amp/600v bridge rectifiers, will these work? I assumed they would I just wanted to check first.
Yes
Quoted from vid1900:Next on the bulletproofing is to tie C26's NEG leg to ground.
These Bally boards had some strange designs and we can make them more reliable .
Note also the completely vaporized board trace. I replaced that trace with a wire, hot glued to the board.
Apologies for the stupid question here, but exactly what type of wire are you using here? I think I've read that this should be 18 AWG? I'm assuming silicone and stranded?
This will be my first attempt at this and while I'm struck with a little concern I also need to remind myself that with some care this isn't that tough.
You can use 20 or 22 ga wire, I prefer stranded, (since I have it on hand), but solid will work. There really won’t be any current on the jumper.
Quoted from Biju:Apologies for the stupid question here, but exactly what type of wire are you using here? I think I've read that this should be 18 AWG? I'm assuming silicone and stranded?
You can use silicone or PVC coated wires. I'm partial to PVC, as they feel a little stiffer and tend to be a slightly smaller outside diameter.
This page was printed from https://pinside.com/pinball/forum/topic/vids-guide-quick-bally-driver-board-repair-bulletproofing/page/5 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
