(Topic ID: 227522)
Vids Guide: Fixing Stripped Screw Holes In Wood
By vid1900
5 years ago
  • 7 posts
  • 1 Pinsider participating
  • Latest reply 5 years ago by vid1900
  • Topic is favorited by 26 Pinsiders
    10
    #1 5 years ago
    Holes in Pinball strip out all the time, because steel threads are harder than wood fibers.
    95% of all stripped holes are for #6 or #8 screws.
    Lucky for us, Bamboo Shish-K-Bob skewers are exactly the right size to fill these holes in a single step (no need to keep adding toothpick after toothpick).
    Skewers are generally poorly graded, so you often get a variety of diameters in a bag. This actually works in our favor when we are looking for a nice fit.
    A whole bag of Skewers is $1, and it will last most of you guys a decade or more.
    The skewers are pointed on one end, perfect to match the cone shaped hole made by the pointed screw.
    You can sharpen them for the next use (if you want the even the tip of the hole filled) with a normal pencil sharpener.
    #2 5 years ago
    Sometimes you are repairing holes that are blown out from the post being loose for years.
    Other times you have a more delicate surface, like this Fender Stratocaster that I refinished:
    #3 5 years ago
    Put a drop of wood glue (Elmers is fine, you don't need anything fancy) either in the hole or on the tip of the Skewer
    #4 5 years ago
    Gently tap the glued skewer into the hole.
    A small hammer is fine, it does not have to be bashed in, just snug.
    #5 5 years ago
    Now take a pair of Flush Cut Diags and cut the Skewer just slightly below the surface
    Here you can see the plugged holes:
    #6 5 years ago
    You don't even have to wait for the glue to dry, just run you new screw right into the center of the skewer.
    The screw will expand the wood fibers making the hole tougher than the original (of course Bamboo is a stronger wood than Maple too).
    If there is a little bit of wood above the playfield, just mash it with a hammer and run your screw in.
    #7 5 years ago
    If you have larger holes than a skewer, you can repair them with a Fluted Dowel
    The fluting that is pressed into the wood, allows the excess glue an exit (you know all that "you can't compress a liquid" physics stuff).
    The moisture from the wood glue expands the compressed Dowel, again making a stronger hole than the original.
    Dowels come in English and Metric sizes. You **may** have to drill your hole out to the next standard dowel size, so if you hole is a blown-out 1/8", you may have to drill it out to 3/16" so you can tap in a standard 3/16" dowel.
    This page was printed from https://pinside.com/pinball/forum/topic/vids-guide-fixing-stripped-screw-holes-in-wood and we tried optimising it for printing. Some page elements may have been deliberately hidden.
