I can not figure out why the LAUNCH button light does not fully illuminate. Every other light operates normally, including the START button connected to the Coin interface board. All are LEDs. It flickers, not the normal on/off flash, very very dimly. The light is so dim it is only visible with the switch out of the housing. It is lit by row 6, and the power comes from the Coin interface board. All playfield lights lit by row 6 light brightly, except LAUNCH. However, the LAUNCH light does work normally if the input of the LAUNCH diode is connected to a row 8 source. I have tried the following things:
LAUNCH lights brightly if I connect it to a Row 8 source on the Coin interface board, playfield connector, or Row 8 on backbox connectors J124,125, or 126.
Otherwise, it flickers extremely dimly when connected to a row 6 source. It is also very dim with a row 7 source.
I replaced the diode on the coin interface board. No effect.
I replaced the bulb with a working bulb. No effect.
I eliminated wiring from the backbox as an issue to the coin interface board, by connecting a wire direct between the pins on J124,125, or 126 to the input diode for LAUNCH on the Coin interface board. The Row 8 pins on those connectors light the bulb brightly, but rows 6 and 7 pins exhibit the very dim light. Those same pins drive the Row 6 bulbs on the playfield just fine.
LAUNCH does not light if I connect it to a Row 6 source with a separate wire direct to the LAUNCH diode to either a playfield Row6 connector or direct to the power board connectors, J124,125, and 126 for Row 6. For instance, the “M” in Martian is a row 6 light, and it lights fine. If I pull the “M” connector, and wire direct from the Row 6 pin on that connector the LAUNCH diode, LAUNCH does not light.
Any ideas?
