New! Dark mode!
(Topic ID: 272468)
Vertical Lines on Display - World Cup 94
By AJSDave
3 months ago
  • 11 posts
  • 4 Pinsiders participating
  • Latest reply 49 days ago by PinballManiac40
#1 3 months ago
A set of evenly spaced vertical lines showed up on my world cup 94 a few days ago. Now the display seems to be responding slower and more pixels are disappearing. Is this a sign that the display is bad, a connector issue, or possibly a board level failure? Any thoughts would be appreciated. thanks! Dave
#2 3 months ago
Classic symptom of ribbon connections.
Reseat the dot controller-to-display ribbon a few times. Make sure it is seated correctly on both ends when done.
Chris Hibler - CARGPB #31
Http://chrishiblerpinball.com/contact
http://www.PinWiki.com/ - The new place for pinball repair info
#3 3 months ago
Quoted from ChrisHibler:
Just as Chris suggested.2019-02-02 14_20_45-WPC ribbon cable to reseat - Paint (resized).png
#4 3 months ago
To clarify, this is the skinny ribbon cable on the right in the photo with no arrows pointing to it.
#5 3 months ago
Quoted from Crash:
Yeah, I did misquote Chris without realizing it. I never seen that one cause the vertical lines, only the one I posted about.
#6 3 months ago
I re-seated the cable 4-places as in the picture. It worked! Thanks all!
1 month later
#7 72 days ago
Re seating the cable fixed the display problem, but it has reoccurred three times since then. Each time re-seating the cable has corrected the problem, but it seems the fix is temporary. Any suggestions on a longer term fix? Replace the cable? Thanks!
#8 72 days ago
Yep. Time for a new cable. I never had any issues with these at the bottom of the page.
http://www.docentelectronics.com/httpdocs/AmusementGames/Pinball/Bally/BallyPinball.htm
#9 71 days ago
Thanks for the suggestion! Dave
3 weeks later
#11 49 days ago
No problem. Playball !!
$ 69.95
$ 399.95
Pin Stadium Pinball Mods
$ 349.95
Flashinstinct
$ 50.00
Malden, MA
