2010 Subaru Outback. It fits a WPC game, with some work.
Photo is from a client's vehicle. How we made it work:
-You'll probably need two people for this. One to lift and pull the front of the game and one to push.
-Remove bottom rear seat. There are two hooks on either side, you grab under the front and lift up sharply and the seat will come loose. Not sure if this was totally necessary, but I think it gave a little extra room at the front of the game so it didn't wedge upwards as much.
-Pull back the rubber seal at the top and bottom of the hatch and remove the upper trim piece and the lower trim piece. The trim is all held in place with clips and will pop out. Replace the seal after removing the trim pieces.
-Put the game in with the coin door towards the front. Have the strap's rachet and hooks on the side of the game. It won't fit if they are at the top. You may have to open the coin door so the person in the front can get a hand hold and pull the game.
-The latch for the hatch might be in the way to get the game out. You have to lift it over and it might take two people. Be prepared to remove the latch (two bolts) just in case.
-Note, you'll probably scratch up the headliner a little bit at the opening to the hatch. The game rubs the headliner when going in.
-Also be aware that you are sliding the game on the carpet and it is tight. If you have loose or splintered plywood at the front or back of the game, you may peel off a layer. You might want to put painter's tape along the front and back to protect from peeling the plywood.
I didn't help unload so I can't comment on how hard it was to get the game out.
