Update of where we are with testing:
With all targets reset game boots up like it should.
Able to get into switch test mode - 0 displayed until a sw is engaged and reads sw correctly.
Measured resistor under playfield 3.3K with +5 V
When Z drop target is hit it scores.
When Y drop target is hit it tilts
When X drop target is hit it resets the game
Measured +5 Volts on both sides DT SW diodes
Vector, like Centaur, like Fathom, ran out of switch strobes.
--- Check continuity from,
Check A4J4-16 gray-brown +5 volts to resistor 3.3k ohm
---- under playfield.
Continuity between A4J4-16 and 3.3K resistor.
---- resistor orange-blue to A4J4-5 (ST 5)
Continuity between A4J4-5 and other side of resistor.
---- = X,Y,Z, drop targets switches (anode side).
Continuity between resistor and anode side of X,Y,Z DT.
This game was playing and then stop all of a sudden, before this issue.
Hope something in here gives insite
