Hey guys, half the small back lights on my TMNT machine's back box isn't working, and the larger bulbs are neither working. Since I believe the easiest route would be to just make a jumper to the first bulb in the circuit, and possibly do the same to the larger back box bulbs since none of the lights flash I believe. I would replace all the back box bulbs with LEDs so they don't overdraw that single circuit, and all would be well. Is this an appropriate route to take? I can take the connector and put pressure on it and the upper small LEDS will work, so I guess its a bad pin, even though the connector appears perfect.
