(Topic ID: 124924)
Using both flippers resets the machine
By snowvictim
5 years ago
  • 9 posts
  • 7 Pinsiders participating
  • Latest reply 5 years ago by WIKED
#1 5 years ago
Hey everyone!
I have problem with my TZ game. Basically, when I use the plunger and shoot the ball into the scoop, after it pops out of the slot machine scoop if I press both flipper buttons it causes the game to reset (GI goes off, DMD goes off, then it goes back to "Testing...").
I have two LED light mods that light up the scoops that I made myself. I noticed that they can sometimes make a short (the metal wires from the resistor or LED can sometimes touch the metal elements of the playfield, so I covered them with insulating tape). Could this be the reason the game shuts off? I'm guessing something else is up since flippers aren't really related to GI lighting.
#3 5 years ago
That's highly possible since I got the game with one that snapped off so I soldered it back on (with 18AWG wire lol I know shut up... ). It's not even a proper PCB bridge rectifier. I got a few replacement KBPC3502W ordered.
#4 5 years ago
Quoted from snowvictim:
UGGGGGGGHHHHHH.
BAD!
/dopeslap
#5 5 years ago
Check your voltages, but low by the sounds of it?
#6 5 years ago
Have that bridge repaired; that sounds awful. And check your 5V. That's what makes games reset. Could be low for a variety of reasons. Don't shotgun this; slow and steady and figure out where your voltage is dropping. Follow the power from the AC input and trace it to the MPU.
Marc
#7 5 years ago
1) rectifier as noted
Else...
2) http://pinwiki.com/wiki/index.php?title=Williams_WPC#Game_resets
Else...
3) http://kahr.us OR new board
#8 5 years ago
Replaced that shitty BR for a PCB KBPC3502W, works like a charm now.
#9 5 years ago
I use kahr's little board until I get around to replacing the BR2 & C5. Works like a charm.
$ 22.50
$ 259.95
Pin Stadium Pinball LEDs
