(Topic ID: 107993)
Using a System 11 board in a System 11b game?
By Jive
9 years ago
  • 10 posts
  • 7 Pinsiders participating
  • Latest reply 9 years ago by Jive
#1 9 years ago
I have a Police Force that came with a System 11 MPU and Road Kings ROMs. I know I read somewhere about using this board in a 11b game, but for the life of me, I cannot find the site.
I ordered the full EPROM set from That Pinball Place, which includes CPU ROM Set (U26 & U27, L-4 Sound ROM (U4), and the L-2 Speech ROM Set (U19, U21, U22). I wasn't sure I needed all of them, but better to be safe than sorry.
What do I need to do (if anything) to get the 11 board to work?
#2 9 years ago
I think it was on pinwiki
#3 9 years ago
sell it to someone who has a highspeed and cant find a board.
buy the system11b .. keep the ( probably quite a bit of ) change
#4 9 years ago
Pinwiki confirms the original Sys11 board will work in later generations, although you'll need to add some missing diodes and short a couple of pins to ground on J18....
http://www.pinwiki.com/wiki/index.php?title=Williams_System_9_-_11#MPU_Driver_Boards
Or as wiredoug suggests, find someone to trade boards with you, the original Sys11 boards are getting harder to track down these days
#5 9 years ago
Thanks, it was Pinwiki!
I may look into selling it, if I could get enough to buy a 11b board, or a new Rottendog board.
#6 9 years ago
I'd modify it as Pinwiki suggests, and use it. You never know when you're going to find a High Speed or Road Kings without a MPU, and decide to tackle it as your next project *then*, you buy the Sys11B board for the Police Force
The difference in price isn't *that* significant.
#7 9 years ago
Yeah, that's about what I've decided. The mod looks easy, and this board is acid free.
My only question is about the diodes, Pinwiki says to use 1N4735A 6v, 1w zener diode. My local Radioshack has a 5.1v, 1w zener, or a 12v, 1w. I would assume the 5.1v should work?
#8 9 years ago
yeah, not that big of a deal using the 11 in an 11B. If someone needing an 11 finds an 11B CPU it's only an amp and a couple of other small parts to revert it back to an 11. Or use an 11A which is compatible with all 4 versions.
#9 9 years ago
Quoted from Jive:
They are .15 cents, just get the proper part:
https://www.greatplainselectronics.com/products.asp?cat=158
#10 9 years ago
Actually, once I took the board out of the machine, I found someone had already did the diode mod.
I put the correct EPROMs in it, and she booted right up to attract mode!!
$ 19.99
$ 39.99
Hardware
Tucson Pinball
$ 18.95
$ 27.00
$ 36.95
$ 54.99
$ 12.50
RoyGBev Pinball
$ 22.50
This page was printed from https://pinside.com/pinball/forum/topic/using-a-system-11-board-in-a-system-11b-game and we tried optimising it for printing. Some page elements may have been deliberately hidden.
