Works fine and no other areas out other than the far right vertical column. I figured someone could use it to try and fix or replace one that's worse shape.
it appears that where the glass broke (upper right corner), the trace for that vertical line probably broke. that's a relatively easy fix with some conductive epoxy or a conductive paint marker.
Great to see you're enjoying Pinside!
Did you know Pinside is able to run thanks to donations from our visitors?
Please donate to Pinside, support the site and get anext to your username to show for it!
