Just when I was feeling good about "shopping out" my first machine, I have hit a roadblock and am feeling like I'm in over my head. I just rebuilt my upper flipper on my BK2K after it started being extremly "lazy" last week. It was working great after the rebuild kit was installed. Today I rebuilt the right lower flipper (I figured if one was going bad the others aren't far behind). While resoldering, I unknowingly switched the two wires going to the EOS switch. When I turned the machine on and tried the flippers, the right flippers didn't work. Once correcting my mistake (and replacing the fuse in F5), I tried the flippers again. This time the lower playfield right flipper worked great, but the upper playfield flipper (right) was only slightly "jumping". I happened to have a new coil so I swapped it out. Unfortunately, I read my wire labels incorrectly, and I wired the coil incorrectly (I switched the wires going to the outside lugs) (burned another F5 fuse). I have now replaced the fuse, turned the machine back on to test the flippers, and the upper flipper doesn't even "jump" the slightest bit. And it burned the fuse after trying the flipper only a few times. I am now stumped. I do believe I have the wiring correct. Did I burn something else out besides a fuse? I don't know where to turn. Please help
