(Topic ID: 89927)
Baseball; Update Williams C-5161 Batter Unit Assembly with Slugfest Bat Parts.
By SteveinTexas
7 years ago
  • 22 posts
  • 11 Pinsiders participating
  • Latest reply 5 days ago by phillyfan64
#1 7 years ago
Back Story
Why do this? I was unable to find the C-5161-4 unit for a 1962 World Series restore. This earlier versions with modifications and coil upgrade to a H23-870 is just as good. On review of four batting units and talking with other baseball game owners it became evident that unless they were routinely lubed bat units linkage can become worn over time and not function properly.
The original C-5161 and C-5161-1 driver arm has a bat with a shaft similar to a flipper shaft and an assembly arm. This three piece arrangement (bat and shaft are two separate pieces) was replaced on the ‘Official Baseball’ C-5161-2 game with a more modern version three piece arrangement.
The early C-5161-2 more modern arrangement has a cotter pin on the shaft that allowed the bat and shaft to be fitted from the top of the playfield with a smaller hole in the playfield. This was simplified a year or so later to the final two piece arrangement (not changed since) and although not really necessary the cotter pin was nice engineering in my view.
Restoration Good News
You can replace not only the C-5161, C-5161-1 batter units but also the C-5161-2, C-5161-3 and C-5161-4 assembly, shaft and bat with current Slugfest parts purchased from Marco Specialties.
The assembly shaft may require on the C-5161, C-5161-1 and C-5161-2 batter units that the assembly frame collar that goes through the playfield be drilled out to a 3/8" diameter hole to fit the slugfest shaft.
C-5161-1 Batter Assembly Diagram with Part #'s
What we started with shown above.
C-5161-2/4 Batter Assembly Diagram with Part #'s
a) Instructions to replace C-5161 and C-5161-1 Bat and Handle;
Slugfest Items to buy are shown below;
1. # A-6338 Slugfest (WILLIAMS) DRIVER ARM ASSEMBLY $29.95.
2. # 02-2966 Slugfest (WILLIAMS) SHOULDER STUD ROLLER $5.65.
3. # 02-2750 Slugfest (WILLIAMS) ROLLER DRIVE ARM $2.00 (Note; currently out of stock part. Salvage the original sleeve 23A-6312 from discarded assembly arm assembly A-4689 by drilling out rivet).
4. # 20A-8798 is a ¼”-28 hex nut. (Fine thread not available at box store).
5. # 03-8516 BASEBALL BAT (see pic below) $12.50.
6. # 10-32 elastic stop nut to hold the bat on (see pic below, has a fine thread and not available at a box store).
Bat (#03-8516) installed with lock nut (#10-32 Elastic stop nut)
b) Exchanging the ‘Batter Unit’ parts
1. Remove the bat shaft A-4691 cotter pin from the assembly collar.
2. Discard the bat & shaft, and assembly arm. (See picture below).
What parts we will discard; A-4689, A-4691 and bat 23A-6323 shown above.
3. Keep the old assembly arm and salvage the original sleeve 2A-2750 by drilling out the rivet. Then discard arm.
4. Drill out the assembly frame collar with a 3/8” drill bit.
5. Fit the new Driver Assembly arm.
6. Fit the new shoulder stud roller, salvaged sleeve and secure with a ¼”-28 hex nut.
7. Fit new bat and secure with a #10-32 elastic stop nut.
Upgraded Batter Unit
Batter Unit opens switch after bat action
#2 7 years ago
Steve,
do you have the old metal bat still?.........
Mine has the new bat which probably accounts for the lack of modifications and mine is a newer series frame and mech.
Have you been able to find the bat stop rubbers?
I would like to see the differences between the regular thru the 4 series bats some how. Maybe ill go scrub the parts manuals.
interesting
--Jeff
#3 7 years ago
Jeff,
No I have only the bat shown in the discarded picture in the original thread.
Per the books on the planetary pinball site the bat I refer to above is only one shown. The earliest book is for the 52-60 time period but is not inclusive by far. The link is attached.
http://www.planetarypinball.com/mm5/merchant.mvc?Store_Code=PP&Screen=BOOK
I have not looked for the rubbers, seem easy to make though. It a quite soft rubber.
Steve J
4 months later
#4 7 years ago
Jeff,
Do you mean the bat shown in post 1? If you do you can have it. Pm me were to mail.
2 years later
#5 4 years ago
What's the number of the replacement switch and spring for your "upgraded" bat unit?
I found the rubber bumper at Marco as Williams # 23-6312 (just $1.99 for it).
#6 4 years ago
Quoted from KenLayton:
Don't think there are replacements for the switch
I make the switch from PBR parts and the spring is a #10-431 from Marco and in stock.
#7 4 years ago
The switch looks like a Bally flipper EOS switch from an Eight Ball Deluxe.
The spring is called out in the 1963 parts catalog as Williams # 10A-101-1A, Extension Spring, 2.50" long by .250" diameter. I'll have to check out the spring section at my local Ace Hardware and see what I can come up with.
How about adding the rubber bumper to your upgrade parts list? It is a different color and better material than the original one was.
#8 4 years ago
7-22 Update; Finally back in-country and had time to research what Ken asked for. The spring is in stock at Marco 10-431 and no need to make one. The slugfest has no switch so that you easily make from parts from PBR or equivalent.
The current replacement parts that Marco Specialties have in stock for the Slugfest batting unit that are universal with all earlier assemblies since the late 50's are as highlighted below.
I have attached the Slugfest parts list from the manual for part # confirmation.
Hope this helps.
#9 4 years ago
Reserved for updating
#10 4 years ago
There's one part that is unavailable that need to be remade, the drive arm assembly, (#3)
#11 4 years ago
Marco Specialities have been out of stock for over a year. I heard they were not planning to make them. I have been asked about it a lot and all my spares are gone now.
Only guy that has the skills and inclination is Scott Webb (G43crazy) How about it Scott?
#12 4 years ago
I have a coupe of NOS one in the rat hole and have not thought about that part . Hey NYP send me a photo of your old
one . [email protected]
#13 4 years ago
I have a spare batting mech base, probably with a few oddball parts still left on it. I had it squirreled away for a just in case situation but would cut it loose if someone gets in a pinch.
3 years later
#14 6 months ago
Anyone have the A-6338 Slugfest (WILLIAMS) DRIVER ARM ASSEMBLY?
2 months later
#15 3 months ago
necro bump..need the SLUGFEST A-6338 myself..anybody?
3 months later
#16 16 days ago
Old thread. This is for a Williams Upper Deck. I haven’t torn this apart yet but the bat is really loose. Do Slugfest parts work for this assembly also?
#17 16 days ago
Quoted from phillyfan64:
Yes they do.
#18 16 days ago
What parts do you need?? That looks pretty good to me just disassemble and a good cleaning. I have done several of these on WMS baseballs from 56-63 and thats one of the better looking ones. Once you clean all that old grease out of there (including the coil innards), add some Super Lube to where metal rubs on metal and I bet that unit will be snappy like new. ......unless I'm not seeing something
#19 16 days ago
I’ll take it all apart and clean it up and see what I have. I’m pretty sure it at least needs a new bat. It has a lot of play in it without anything else moving.
#20 16 days ago
I have the NOS connector arm for the bat assembly and NOS pitching motor if you land up needing them.
#21 15 days ago
Quoted from PinballAir:
Awesome, thank you. I will let you know.
#22 5 days ago
Just an FYI for anyone looking, Pinball Resource has a replacement for part A-6338. It has sort of a bronze finish to it. It comes with the correct lock nut.
36AA9C0A-9F30-4BA3-92EA-0988A6368CB0 (resized).jpegD709608E-20B6-4E76-8537-0670997A4010 (resized).jpeg
