(Topic ID: 11546)
Up next: Paragon in the rotisserie for a restoration (Completed-3-13)
By Whridlsoncestood
7 years ago
  • 107 posts
  • 29 Pinsiders participating
  • Latest reply 7 years ago by vster23
There have been 54 images uploaded to this topic. (View topic image gallery).
There are 107 posts in this topic. You are on page 1 of 3.
#1 7 years ago
Flash Gordon is out the door and Paragon is up next on the Rotisserie. A lot of work ahead on this one, but I am very excited it. Spent a night Removing all the mylar and glue and gave it a quick wipe down to get the heavy grime off. MF and Alcohol are next to try and get the ground in dirt out.
First the starting pictures
#2 7 years ago
After mylar removal/wipedown
#3 7 years ago
Few More
#4 7 years ago
Oh yea! The Hulk part two!
#6 7 years ago
I'll be starting one next week, I may have a few ? for you. Like what do you do of all most all my inserts are sunk in? I will be getting a new PF well new to me. its missing 2 inserts, you know where to buy new ones? or can they b replaced without replacing all and still match ( look the same)?
#7 7 years ago
Not sure where to get new ones. Maybe contact Steve Young at pinballresource.com?
All of these are sunken in. I will do touch ups around them and then fill with polycrylic clear when playfield is laying level and then sand down flush. Other option is to pull every insert. Sand down the face until it is flat, re install flush, glue in, and then put new decals on the inserts. My more time consuming and may end up breaking even more inserts.
#8 7 years ago
Oh yea Part 3!
#9 7 years ago
I'm looking forward to this. I loved your Hulk restoration thread, btw!
#10 7 years ago
Quoted from Whridlsoncestood:
What did you use to remove the mylar adhesive? I'm not having much luck in getting the adhesive to let go on my Paragon PF. I froze the mylar off easily. Thanks.
#11 7 years ago
I let goo gone spake for about 20 minutes and then I scrape away a layer of the glue. Then repeat and eventually it's will be all gone. Very time consuming and tedious
#12 7 years ago
An hour later and a tired arm gets you this.
50 percent of a playfield clean. Taking a break to play Hulk and then diving back in. I am also keeping a time log on this playfield restoration. I didn't do it for Hulk and I know it was way too many hours.
#13 7 years ago
Also forgot. Here is the scanner that showed up this weekend. Will be using it to restore the thousand text below all the center inserts.
#14 7 years ago
I love the artwork on that pin. Scanner is a great idea, can't wait to see how it turns out.
#15 7 years ago
That is the exact model scanner I use. I have two of the "thousands" area to recreate on waterslide decals. I have two playfields, one that was in the game and one I bought. The one I bought is a little nicer than the one I had originally. I guess I'm fortunate in that mine do not have near as much insert wear as yours. My most time consuming task will be leveling every one of the inserts.
Best of luck on your restoration!
#17 7 years ago
2 1/2 hours, 6 large MF foam pads, 16 oz of 91% alcohol and a splash of naptha and I have a clean base to start with. And that doesn't include Mylar removal/cleanup.
Next step is filling in all areas of missing playfield and sanding down all the kickout holes and shooter lanes to clean smooth wood.
#18 7 years ago
Few more
#20 7 years ago
Let us know please the reference of waterslide decals you use .
Is this a scanner you modified ?
Great project
#21 7 years ago
SWEET!!! ...I'm anxious to see the pics from this restore. My Paragon playfield is in almost the same shape as yours, and I'm excited to see what you'll do.
#22 7 years ago
It's a HP 4600. No modifications. I will link the decal paper I use after I try it out. The last stuff I used was better suited for a laser jet printer. Will be finding some that's better for laser jet printers
#23 7 years ago
Would you consider selling waterslide decals? Whats the best way to remove the wire guide things off the PF?
I think I can, I think I can, The good part is the PF I'm working on is a spare.
#24 7 years ago
Good luck Whrid.
You certainly have your work cut of for you on this one!
#25 7 years ago
your off to a great start
#26 7 years ago
wow, can't wait to see how the artwork turns out on that wing!!! i'm sure it will turn out well compared to your flash artwork.
#27 7 years ago
Very nice. I bought a Paragon with the intention of doing the same, but then re-evaluated my decision based on that fact that I really don't have the patience for resto work, so I sold it.
#28 7 years ago
Quoted from ranpin:
Whridlsoncestood said:It's a HP 4600. No modifications. I will link the decal paper I use after I try it out. The last stuff I used was better suited for a laser jet printer. Will be finding some that's better for laser jet printers
I can make you some. No charge. How many you need? Talking about the thousands text right? For the wire guides put something under them like a credit card and pry up a little bit on each end with a screwdriver or such until it's free
Quoted from Ballsofsteel:
Need to look through archive pictures and see if there are any good closeups of this area. If not anyone with a paragon want to snap me a good high res picture of the center insert area?
#29 7 years ago
I got a good one ill send pic, or post here.
#30 7 years ago
Quoted from ranpin:
Whridlsoncestood said:Need to look through archive pictures and see if there are any good closeups of this area. If not anyone with a paragon want to snap me a good high res picture of the center insert area?
Is it complete still? Jdswainjr@gmail.com
#31 7 years ago
Its still complete, I can send you more if you need.
#32 7 years ago
I'd also be VERY interested in getting a copy of these......pretty please.
Any thought to creating an entire bonus section decal? Maybe something that would cover the 'traingle' of numbers 1 through 10? ..and then maybe another decal for the super bonus and multiplier section? I've got very similar wear on my Paragon, and have been trying to figure out the best way to fix it. Here's a pic of mine.....
#33 7 years ago
It seems as though most paragons have this area of wear, having a universal overlay for that section would be a bigtime asset.
#34 7 years ago
Man, that playfield art is awseome! Haven't played Paragon but I dig the detail in that art. Reminds me of the old 60's/70's Conan comics I used to collect.
You must have a very steady hand a ton of patience.
Good luck!
#35 7 years ago
I can look into. Biggest issue is going to be every playfield that has wear like this has cupped inserts. Those will have to be leveled out first for anything to go over it evenly. Same with wood wear. Has to be a nice flat even surface. The bonus area will still have to be painted by hand if it is worn to wood as that is white text. Inkjet won't print white. Laserjet could but I don't have access to it.
It will be a week or two before I get doing these decals for myself. Just how many people are interested?
#36 7 years ago
Quoted from ranpin:
If you have a hi res version could you email it? Thanks.
#37 7 years ago
Im thinking I must b nuts for wanting to "restore" my PF as that is the most wore out spot. I found this Pin in a barn the only thing bad on it now is the inserts as they r sunk. But I only have 650.00 in it. without the cost of the spare PF I got from a fellow Pinsider.
#38 7 years ago
Thanks for the email pictures everyone. After I get this together I will try and make up some more decals for everyone
#39 7 years ago
You are DA MAN~!
#40 7 years ago
1.5 hours of sanding shooter lane, bulb holes, saucer holes and any other cutouts in the playfield. I think I am ready to start painting tomorrow.
#41 7 years ago
Looking good~!
#42 7 years ago
Gadzooks I love this stuff!
#43 7 years ago
Spent a good chunk of tonight looking at pictures of decent specimens of Paragon and drawing in missing areas. Will start going over it with paint next. IMG_1640.jpg
#44 7 years ago
wow. that is going to get involved. unreal. gl man
#46 7 years ago
Thank you so much for taking the time to document your projects. They are great reads!
#47 7 years ago
Quoted from SunsetPinball:
+1 Especially when it's a pin I own.
#48 7 years ago
+2 these are my favorite threads on Pinside.
#49 7 years ago
This is awesome thanks for sharing!
#50 7 years ago
Oh man, I thought you were going to replace that area with a decal somehow. You've got skillz to pull off that detail. Awesome work!
$ 7.00
Third Coast Pinball
Metal-Mods
2,500 (OBO)
O'fallon, MO
