Quoted from pinballdaveh:Doesn’t the pin reset relay operate off a score motor cam bladed switch that fires at about 350 degrees ? Have you checked the switch on the pin reset motor cam thats used in the pin reset relay hold circuit ?
Yes, the pin reset relay does activate through the score motors wiper and wiper board. He did mentioned that when he stepped
up the 10th Frame unit, and the pins reset, but that travels through another circuit, but it did suggest that the pin reset relay along with
the run out switch on the pin reset motor's cam is doing it's job okay..
Back in the 90s, I got in ball bowlers where the rivets were worn right off the wiper blades. I replaced the rivets, lubed the wiper
boards, and since the mid 90s, they now show very little if any wear, and all has been problem free. These are machines that got/get very much play..
I also had problems with the snowshoe wipers where some would stick and make pour contact. Since the late 90s, I used Remington
Gun Oil (which contains teflon) in those snowshoes, and haven't had any problems. This isn't finding these positive results with just
10 or 12 bowlers. This is using this procedure with many, thus I have to stay with wants been successful..
Some old vendors use to tell me that they don't grease anything. That just collects dust, which probably explains why I find so many worn
wiper blades and full tubes of lube that the manufactures sent with the machines..
