(Topic ID: 249496)
United/Williams '65 Pyramid Shuffle Bowl -keeps blowing 15a fuse
By SweetStash
10 months ago
  • 15 posts
  • 8 Pinsiders participating
  • Latest reply 9 months ago by MD_Pinball_Dude
    #1 10 months ago
    I just set up a Williams Pyramid shuffle bowl game up that I purchased yesterday. After hooking everything up it worked great. I was adding multiple players to the game and now it keeps blowing a 15A fuse. If I replace the fuse and turn the power back on, it instantly blows the fuse..The 1 thru 6 players do not light up and the arrows on the lane do not light up either. I have no clue where to even start looking. Any help is greatly appreciated...
    #2 10 months ago
    #3 10 months ago
    You have a short some where start with looking at if any of the light bulb holders are bent to far causing a short.
    Raff
    #4 10 months ago
    Please post a photo of the fuse block.
    #5 10 months ago
    4th fuse down
    #6 10 months ago
    Check your schematic to see what runs thru there, and start checking for shorts.
    #7 10 months ago
    I'd suggest you make one of those circuit breaker fuses. It'll help you to find the issue and save your money and sanity.
    Did the problem only occur when you tried multiple players? It was working fine on single player?
    #8 10 months ago
    It worked before I purchased it and moved it. I hooked it up and it worked but I didn't plug in the plug for the lane sensors, so the pins didn't go up. I undid the bolts and slid it apart the get the plug and hook it back up. After that it started to blow the fuses. I have been looking at maybe a crimped wire or something. But nothing sticks out that it's bad.
    The game works with multiple players like it should. And tracks scores correctly, it just doesn't light up the players or lane arrows anymore
    #9 10 months ago
    Where do I get a circuit breaker fuse for this? Is it something I can find easily or order?
    #10 10 months ago
    Solder a blown fuse to a circuit breaker.
    There's a pinwiki on it, and I think Vid did something on it also here.
    Sorry I don't have a link.
    Search circuit breaker fuse on this forum and look for the pinwiki thread.
    #12 10 months ago
    Quoted from SweetStash:
    What bolts try to explain abit better so we can help you.
    Raff
    #13 10 months ago
    Just The bolts that hold the lane to the upright cabinet. Nothing that would effect the electrical. So I thought. Then plugged it in and that when it started popping fuses. Besides the lighting not operating, everything else seems to be working
    3 weeks later
    #14 10 months ago
    Did you find the issue?
    #15 9 months ago
    Maybe open it back up with a new fuse installed and see if it blows at startup. If it stays intact, look for a pinched wire along the sides? If it blows, look down into whatever stepper puts the game into multiplayer and see if you have something that may have fallen into the clockworks?
    Flashinstinct
    $ 41.25
    The MOD Couple
    $ 139.00
    Sparky Pinball
    £ 50.00
    Sillyoldelf Mods
    $ 10.95
    Pinball Photos
    $ 67.00
    $ 9.95
    Playfield - Plastics
    $ 65.00
    Texas Pinball
    £ 59.00
    PinballToys
    $ 99.99
    $ 218.00
    $ 159.99
    $ 69.95
    $ 8.00
    Third Coast Pinball
    $ 159.99
    Displays
    PinballSolutions.eu
    $ 2.50
    Various Novelties
    Pinball Wheezer
    $ 125.00
