Have 50's shuffle alley issue
The game was working perfectly until late and now have a problem with the #1 pin play-field switch (the front two, neither one works) it is not registering when the puck goes over the switch. But the #1 pin switch will activate once the 2-8 switch puts up the 2 and 8 pins. So if i press the #1 pin switch it is dead and nothing happens. when i press the 2-8 switch the 2 and 8 go up as they should. Only after the 2-8 go up then the #1 switch will send up the #1 pin but also sends up the #4 pin as well. the #4 pin should not be going up with the #1 pin. Seeing where to start looking? I cleaned all the switch contacts in the relay bank and after a few hours of trying with no luck figured worth asking here for help. Thanks in advance
