Disclaimer: This is NOT a pinball. I'm trying to find a ball bowling forum that is as knowledgeable and forthright as this group, but in the meantime, I'm guessing there are plenty of members that could steer me in the right path.
OK, so I finally got my ball bowler, problem is, it doesn't work. So here is my attempt to bring this thing back to life. I'm going to have several questions and probably move very slowly, but I'm hoping it eventually finds a place in the house.
For starters, I know close to nothing about EMs, but I've ordered the TOP #8 DVD, and am reading through the PinRepair website to gather useful info.
Here's my order of operations:
1) Get this thing to work!
2) Get it working correctly and flawlessly.
3) Make it look pretty.
4) Move it inside.
So far I've got a few top priorities, at least I think they are, here's another list
A) Fix the coffin hinge or spring lock. I have the unit in two haves right now. The hinge nearest the pins was off so the whole top was offset when raised. I placed a few screws in the hinge panel and then noticed it wasn't the same as the other two. Hmmmm. Also, the lane won't stay down on it's own. The lock doesn't hold it on it's own unless I hold the key, but the hook looks chewed up, so that could be the issue. Also, as mentioned, the lanes are separated, so there is a lot of weight missing. Maybe it's supposed to spring up?
Below you can see the worn out lock catch, the hinge in question (which is actually just the small flap on the outside), and then a correct hinge from the middle and lower section to show how these are connected.
B) Test some coils. Clearly this machine had some issues as is evident from the fried coil that was laying in the coffin, along with several bulb receptors taped up, or missing and the wires taped. I also see several coils with their wires snipped. So, I guess I should start testing some coils next? I'll also order some light sockets while I'm at it.
C) Clean up the Bakelite pads and contacts. I think that is the name for them. Anyway, the cool looking metal dots on the reddish plate. I see some yellow markings for alignment already, but I'll make certain to mark any others. Scotchbrite/600 grit sandpaper seems to be the order of the day for these.
D) Check and replace fuses. While 1 fuse is missing, the other 4 look good. Of course I'll pull them and test them to make certain.
OK, well, that's my starting point. Any wisdom, direction, or thoughts are welcomed.
Here are a few more pics, because, well, I like looking at pics!
