just picked up a no fear. when you turn on the game it initializes and appears as thought it tries to fire a ball behind the drop target into the lock. it rarely successfully does this. what adjustments do i need to do here. i also have a new coil plunger tip thing coming and will install that and see if that helps.
also would this explain why sometimes my 3 ball multiball has only 2 balls occasionally?
