I need to remove the upper-left flipper bat on my bally Spy Hunter. However, one of the two hex bolts that holds the flipper bat shaft won't budge, and I've nearly completely stripped the head itself in trying.
Once I realized it wouldn't move, and I was damaging the hex head, I tried:
* Using a Hex allen wrench and once that was stripped the head too much, moved to a Star allen wrench, which also couldn't move it (and has now stripped the head down further)
* Using WD-40 (with the little straw nozzle, and paper towels surrounding it to avoid getting on other parts) to seep into the joint of the screw and loosen it. Didn't help.
* Hitting it (lightly) with a hammer (including using a screwdriver to direct the impact onto the hex screw directly) to loosen it. Didn't help.
* Tried using a lighter to heat the screw (after making sure to remove all WD-40 residue and keeping something nearby to smother any fire if I was wrong. Thankfully, it didn't catch fire). Didn't help.
At this point, any advice is welcome. This is my first time working on a flipper mechanism (though I have read several pages and watched some videos on them).
Otherwise, I see my options as:
(1) Just live it with. Put the other hex screw back in assuming it can tighten down the bat still. This makes the repair I was trying to make difficult (securing the coil stop correctly, which was attached very poorly with a single wood screw burrowed into the underside of the playfield)
(2) Drill out the hex bolt? Is there a particular type of drill bit to use? It would be tricky with the mechanism still attached to the playfield.
(3) Can the flipper bat be removed from the shaft at all? If so, I could just slide the shaft out from underneath, throw it out, and buy/use replacements. At least it would make drilling out the bolt easier.
The first picture shows the flipper mechanism in question. The charring is from a lighter.
The second picture is for reference, showing a different flipper mechanism (upper-right flipper) with a presumably fine hex bolt in it.
