Quoted from pindel:I’m happy with my 12L but when I saw how cheap the 30L was on amazon I had to pull the trigger. Now instead of doing a full disassembly of the nasty coin door I can just raise a few switches out of the cleaner. Massive time saver! Notice how it removed all the spray paint from the door. Temp gets hot and works great so far. If door comes out with any rust it goes into evapo rust for a night then sonic again. Do not leave price plastics in.
[quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image]
How much time did you run it to remove the paint, and how hot?
I went with a 15L model. I think it's the smallest size to reasonably accommodate a wiring harness with the basket removed. The thick end bunch of wires stayed out and had to run through separately, but it worked.
It's my first time using one of these cleaners, so I'm trying to be cautious to not overdo it and risk damage.
I ran the harness for 8 minutes, and the water/solution was completely black. The harness came out clean, but did require a little wiping. I rinsed it afterwards with a jet spray to get rid of the sticky cleaner residue, which probably made wiping it unnecessary in hindsight. Dried it all with focused heat from 1000w halogen bulbs, plus a fan aimed for airflow.
Still trying to learn how to do this, but next time I will remove the coil wrappers first. Oops.
20231228_090054 (resized).jpg20231228_090313 (resized).jpg20231228_093608 (resized).jpg20231228_095339 (resized).jpg
