(Topic ID: 40746)
Uh Oh.....
By Ronnie1114
11 years ago
  • 20 posts
  • 11 Pinsiders participating
  • Latest reply 11 years ago by MrBally
    #1 11 years ago
    I doubt that this is good. What to do?
    #2 11 years ago
    Those wire-wound cement resistors in the lamp matrix circuit get quite hot under normal conditions. Are there more efficient alternatives that don't put out as much heat?
    #3 11 years ago
    .Did you see how burnt they are? I cant see that as being normal
    #4 11 years ago
    Do nothing. Those run hot normally, and ALL boards are discolored underneath them.
    Quoted from Crash:
    Replacing the tip102s/107s with MOSFET equivalents, and then ripping out those resistors entirely. Not a simple mod, but not super difficult. I've never bothered on a machine in home use. If I was routing one, I'd probably bother with it.
    #5 11 years ago
    Quoted from Ronnie1114:
    If you think that's toasty, you haven't seen toasty! Perfectly normal, perfectly fine. Don't touch them puppies when the game is on.
    #6 11 years ago
    Quoted from TheKorn:
    Interesting. Never heard of doing that one before. Just jumper the traces where you remove the resistors, I take it?
    #7 11 years ago
    Ok I was alarmed by the blackness. Im kind of a noob.
    #8 11 years ago
    Remind me to send you a picture of my Shuttle's power board...that's nothing. It's burned to fiberglass, just from the GI!
    #9 11 years ago
    Nothing wrong there. Just goes to show you that these machines were designed for a short life of 2-3 years.
    If you're worried, you can simply check the resistance to make sure they are within tolerance.
    #10 11 years ago
    Quoted from Frax:
    Nice! Gotta love the GI from that era. The GI connector in my old Black Knight got so hot it actually desoldered itself from the board at one point. Decided it was time to rebuild that connector finally at that point...LOL! I miss that game...
    #11 11 years ago
    Quoted from Frax:
    Post it here!
    #12 11 years ago
    I have some boards that went super nova from those resistors i can take pics of if i remember to do so.
    Looks like they where already replaced at one point which is a good thing. I would just keep an eye on it every once in a while. Likely nothing to worry about.
    #13 11 years ago
    Pretty typical. I replace the TIP42s with MOSFETS and use a zero ohm jumper in place of the resistor.
    Looks nice and neat, and will never burn again.
    #14 11 years ago
    Holy $hit Crash, the pins on the 12-pin connector are welded.
    #15 11 years ago
    Hey, let's not forget, that's Williams quality!
    #16 11 years ago
    And, I remind you, this is totally normal for these old boards:
    #17 11 years ago
    When you're done, the MOSFET mod looks like this
    #18 11 years ago
    Thanks everyone, I was having problems with the solenoids and not knowing much figured it was that. Now that I know that those 2 problems are completely unrelated I will keep looking.
    #19 11 years ago
    Solenoids locking on at power up?
    #20 11 years ago
    Quoted from vid1900:
    WMS: Wires May Sizzle.
    This page was printed from https://pinside.com/pinball/forum/topic/uh-oh and we tried optimising it for printing. Some page elements may have been deliberately hidden.
