So I just replaced the transistor (Q5) on my Stern RCT again tonight. First the OPTO receiver stopped functioning (a week after I replaced it) but the switches on that column were still working. Then I went to play today and found that none of those switches were working. Upon testing the switch row/column pins with a jumper wire while in switch test mode, I found that sure enough, the pin associated with transistor Q5 was not registering any switches.
So I cleanly desoldered the 'old' one, removed all solder from the points, and very nicely soldered in a replacement. Everything works great now except for the opto, which I have ordered another $40 replacement board from Marco, to arrive tomorrow or Saturday.
I'm hoping it was just a bad part, but I'm concerned something else is causing this issue. I checked voltage to the opto and it's +4.9ish VDC, inline with other +5 connections around the unit. The opto definitely isn't working though, as I can pass my finger through and the LED indicator light does not illuminate like it did when I first installed it.
My family is really enjoying this game, and we are looking forward to adding more (you guys said nobody can have just one - now I understand why.) But I'd really like to have something that works relatively reliably!
Any ideas or assistance is appreciated! I did replace the ROMs with new display and CPU ROMs, and there is a provision in there for failed OPTOs, so I'm going to play a little while and see if it doesn't work acceptably without the opto installed.
Adam
