Hey guys, So I'm still working on my WCS94 restore and finally got to the main problem I knew of when I bought it (after tackling all the other problems that came up once a closer look was done).
But I knew the game had a bad U20 chip (which luckily for me is socketed, just need to wait for new chips to be shipped) - I had all plugs removed from CPU board and still got ground short error. I'm getting the ground short error on boot and then cannot use the diagnostic buttons, after reading a bunch of stuff it seems to be a bad U20 and maybe a U14. However, if I go into diagnostics (I can get the coin door buttons to work if I flip the #3 toggle switch to off or on (cant remember the name of it, but its the 8 position toggle on the WPC-S board and it does a factory reset)), and go to the all lamps + flashers test, the lights will go on but both flippers will also stroke and then I will loose ability to navigate through the menu by way of the coin-door buttons and have to power off the game.
Basically, I am just lost at this point as to what is wrong. Has the ground short error, but the inserts and illumination Also seem dim (especially when compared to brightness they give off when I go though single lamp diagnostics in the menu). Couple that with the flippers going off in the all illumination + flashers action.
Hopefully something in that makes sense (typing out in an iPhone), would those possibly be an issue with the power being delivered? Wall power is good, but haven't tested board voltages yet...
Thanks guys!
