A & K are the leads for the transmitter LED, and E & C are for the receiver.
The opto on the left clearly shows the schematic symbol for the LED in the position for A & K, and symbol for the phototransistor in the position for E & C.
Unfortunately, I'm not sure if the S & E on the new optos are a manufacturer's mark or are supposed to indicate orientation.
However, if I had to guess, I might say the white dot indicated the electrical source (leg A on the LED for Anode). So, I would try orienting the slot opto where the dot matches the A position on the PCB.
But, since that's just a guess, someone else may know for sure.
Additionally, an LED transmitter should test as a diode when using a multimeter. However, I'm not exactly sure what the results would be for the phototransistor.
