Hello,
I have a TZ that worked great and then started resetting.
I did as much troubleshooting that I could find online and finally replaced the driver board with a new Rotten Dog board.
The machine no longer resets, but the flippers are all weak. Kickouts, bumpers, slingshots fire fine.
I cleaned the optos, the EOS switches work.
I removed the Fliptronics board and inspected it for anything obvious. Everything looks pristine. Also checked the fuses.
When I reinstalled the Fliptronics board and powered on the machine, the line fuse blew.
So I'm concerned. Not being a tech I'm a little worried about replacing the fuse and trying again.
Or would you recommend that I do that? After all, the fuse has never blown before and maybe it was just its time to go.
How could installing the Fliptronics board cause an issue so bad that the line fuse blew?
I ordered a new board from Rotten Dog and it's coming today. But I'm afraid to put it in because I don't want to damage anything.
Advice appreciated.
