Hi everyone, my TZ left flipper button is very soft and feels lose for about half its run. Sure enough, the flipper opto actuator/interruptor is plastic as compare to my right flipper opto assemlby which has a metal actuator. Metal actuator seems to give more resistance on the flipper button.
Which one is original on TZ? Should I replace my plastic actuator?
Also, I never noticed before on other 3+ flippers pins that upper flipper were firing kinda late when pressing the flipper buttons. I always thought that all flippers on the same button fired at the same time but on my TZ, the bottom flipper firing immediately when pressing the flipper button as the upper flippers fire when the button is press kinda halfway.
Is this normal?
