My TZ has developed a strange switch matrix problem on one row of optos. Essentially they flicker in Switch Edge test, when just standing in front of the machine.
The whole row doesn’t appear to activate, so I don’t think it is a short. The wiring and the mini playfield also hasn’t been touched which makes me think it’s not that (though it could be I suppose). I’ve owned it 4 years and the batteries have been off the board (and lithium) in all that time, so I don’t think it’s MPU corrosion either?
Sometimes it doesn’t do it for several minutes, other times it does it as often as the below video:
When it plays up like this it means the ball drains prematurely from the mini playfield because the game “sees” the mini PF exit opto trigger, so it’s quite annoying.
All of the optos on the row work, and activate when tested with my finger. The problem doesn’t seem to affect the other optos or rows. Only row 6 seems to be affected.
All of the optos on that row (and everywhere else) work, as in they trigger when I put my finger in front of the receivers etc.
I’ve pulled the 10 opto board (I assume this is what handles all these optos?) and it doesn’t look obviously damaged, but the solder looks a bit dodgy too to my untrained eye. The cap doesn’t look like it’s leaking? I cleaned all of the connector pins with a fibreglass pen and isopropyl but it’s made no difference. Are these boards prone to failure?
One other thing to note - and it might be my imagination - but I swear I can hear a high pitched noise around that area of the playfield, which might be the board itself? I can’t be sure of this though.
AB438C57-8EE9-4598-832E-44ED86BF796D (resized).jpeg3DD5F152-CF82-4538-AA65-B1A4EF6175E4 (resized).jpegE19BAA85-121A-48C7-B36D-B9967C06D9B6 (resized).jpegD63C2BCC-52AC-45EB-9154-DF90DF222A94 (resized).jpegA0F17284-1060-461F-8E0B-E556CBC47E10 (resized).jpegCBE61DC4-D432-4A18-8493-E94C91B36949 (resized).jpegFF6D9079-6C2F-4266-B65D-685F55339E04 (resized).jpeg
