Hello Again!
The last issue I have with my TZ is the slot machine not functioning when a ball enters or when you plunge the ball past the skill shots. The solenoid will not fire or recognize that the ball is in there. After a few moments the machine does a search and will dispense the ball. The machine is level and the solenoid will fire corectly in test mode. The switch however will not close when I test it. I am assuming it is the following switch and I am going to replace it: Slot Kickout 5647-12693-25. Should this resolve my issue or could it be something else? It's funny cause every once in a while it does work as it should, but most of the time the game needs to try and find the ball and dispenses it that way. Do i also need to worry about the Slot Proximity A-16535 switch as well? Where exactly is this as it looks like it is under the Slot scoop to get to it. Any feedback would be great.
