(Topic ID: 185946)
TZ shuts off (resets) ...
By gubonic
2 years ago
  • 11 posts
  • 8 Pinsiders participating
  • Latest reply 2 years ago by PinballManiac40
#1 2 years ago
I turn machine on and sometimes, while playing, the game will shut off by itself. Sometimes it'll reset and sometimes it will stay shut off. When it stays shut off I have to turn machine "off" and back on physically by flipping switch below machine. And even then sometimes machine won't immediately turn back on. When it doesn't turn back on I wait a bit (10-20 mins.) and then it'll turn on.
When the problem first appeared the machine didn't reset/turn off too often (maybe every 20 or 30 plays). Problem seems to have gotten much worse over time. In fact, sometimes I will turn on machine and let it sit for 5 or 10 minutes and then it will just reset, or turn off, for no apparent reason.
Any thoughts and comments on possible problems/fixes would be greatly appreciated.
#2 2 years ago
You either have a weird sort somewhere, or (more likely) your 5v is not stable. Buy one of Rob Kahr's boards or go through the pin wiki on resets.
http://www.pinwiki.com/wiki/index.php
#3 2 years ago
Try reseating J101, J102, J114 on the power driver board and J210 on the MPU. As you remove especially J101, look for burnt pins and discolored connector housings.
#4 2 years ago
Have the batteries been changed? any acid damage?
#5 2 years ago
www.kahr.us
#6 2 years ago
Check pinwiki, sounds like the varistor has gone bad. Easy fix if that's it.
#7 2 years ago
Quoted from Mitch:
There is no acid in an alkaline battery. Cleaning methods for acid damage will be counter productive.
#8 2 years ago
Take the varistor out to test - you don't need it for the game to run. You may want to replace it if it has indeed gone bad though, it protects from overvoltaging
#9 2 years ago
Do you have a multimeter?
#10 2 years ago
Quoted from YeOldPinPlayer:
I know that as do most experienced pinball people, batteries leak alkaline which is a base and must be neutralized with acid. Seeing as this is a new member i didn't want to confuse by saying alkaline damage. Now if he posts a pic with damage I would have clarified and led him in the proper direction.
1 month later
#11 2 years ago
Any progress?
$ 9.95
pinballmod
$ 95.00
pinballmod
$ 999.00
$ 279.95
$ 15.45
KAHR.US Circuits
$ 90.00
Lighting - Under Cabinet
$ 45.00
Just 3D Mods
$ 159.95
pinballmod
7,500 (OBO)
Carolina Forest, SC
$ 78.99
$ 63.00
$ 20.99
Lee's Parts
Trade
Machine - For Trade
Pleasanton, CA
$ 10.95
Sparky Pinball
Santa Clara, CA
$ 229.99
$ 279.95
pinballmod
