New! Dark mode!
(Topic ID: 279746)
TZ right ramp diverter issue
By misfitdart
2 days ago
  • 6 posts
  • 3 Pinsiders participating
  • Latest reply 2 days ago by misfitdart
    #1 2 days ago
    Well I've got a stumper....right ramp diverter only buzzes or slightly opens, check in solenoid tests same thing, when I ground coil it works perfect so can't be mechanical, traced wire to power board and ground pin and it works perfect so can't be wiring from board to coil...figured maybe transistor so replaced that on power board same issue....any thoughts?? thx in advance
    #2 2 days ago
    Coil stop or rubber grommet there and not worn ? If the plunger rides to low in the coil you don't get a full whack.
    When you ground the transistor, it's getting more power.
    #3 2 days ago
    Quoted from LTG:
    thank you!! I just PM'd you
    #4 2 days ago
    I wouldn't rule out ribbon cable between CPU and driver board.
    #5 2 days ago
    It doesn't happen often but consider the possibility of a weak coil.
    My divertor would just sit the and hum every 5th or so activation. I checked coil solder connections, reseated ribbon cables and board power/grounds. Also checked resistance of the coil vs a new one which were the same. Eventually put the new coil in as a hopefully last ditch effort and it's been working great since. I put the old coil in another machine's knocker and it just hummed when activated.
    #6 2 days ago
    reflowed the solder at the j130 and boom, problem solved, thx all!!
    Filament Printing
    Apparel - Unisex
    Pinball Wheezer
    $ 25.50
    $ 299.99
    $ 29.00
    $ 299.99
    $ 18.99
    Comet Pinball
    $ 40.00
    Arcade Arts
    Gameroom Mods
    $ 28.00
    $ 28.50
    $ 48.00
    $ 199.99
    Cabinet - (Alt) Translites
    FlyLand Designs
    Pinball Pro
    $ 49.99
    Bent Mods
    $ 9.95
    $ 7,599.00
    Little Shop Of Games
    € 8.10
    Buthamburg
    $ 199.00
    Lit Frames
    $ 109.99
    $ 1,099.00
    € 200.00
    Buthamburg
    $ 28.00
