So I over paid on a TZ through eBay. Mainly because it was only about an hour from my house. It also had an original silkscreened cabinet that was nearly unfaded or banged up. The playfield looked like it was in excellent shape without any scoop wear or insert edging. Well reality reared its head after I got it home and was able to start digging into it.
The front cabinet panel was severly separated from the sides. So much so that both the left and right corner blocks were split in half. The only thing holding them in place was the leg brackets. Sadly, someone had attempted to shore it up by driving a drywall screw through the front of the cabinet to draw it in to the side panel. Thankfully whomever did it at least placed the screw high enough that when the lockdown bar is in place you can't see it. My perfect silkscreened artwork can be saved after all.
I was comptemplating having Bryan Kelly restore this after he finishes my AFM but since I need to shore the front up which entails pulling the playfield, I decided to do my homespun version of a restore.
Some pics to get started
I forgot to take pictures with the screw in and show how the front panel was seperated. Oh well. In this picture you can see the indentation in the top left corner where the screw is. The yellow dot is wood glue seeping out.
Split corner blocking
All braced up
Did I mention she was a filthy f'ing pig. I don't think anything was cleaned, ever.
Just started cleaned and sanding. Still need to take the cabinet vent screen off and lot more sanding but I'm tired and done for the night.
Oh, I thought I would add a few Picts of the alien saucers I painted for my AFM that is going to be restored
