First disconnect all 3 connectors : J116, J117 , J118. Measure TP1 again (and or look at LED7, is it lit now?) do you have voltage now (DC Volts, a straight line and a dotted line)?
Measure in AC (wavy line on meter) at J112 between pins 1 and 5 , what do you have ?
Again between J112 pin 1 and both sides of the F116 fuse, what do you have (Still AC)
This unregulated 12V dc doesn't power anything on the board itself, it feeds the Coin door, the Dot matrix controller and the opto boards.
If the voltage reappears when you disconnect J116 ,J117 or J118 then one of these devices is pulling down the voltage.
If you have AC at J112 and the fuse and nothing at TP1 , then possibly the BR5 might be broken , or the filtering capacitor might have issues.
The bridge can easily be tested using a multimeter in it's diode test mode. You'll have to pull out the board to test the bridge pins.
