This is the post guarding the entrance to the piano scoop on Twilight Zone. From straight on, it appears vertical. But from the side you can see it's leaning slightly back. It doesn't move when I push on it and ball strikes rebound solidly. Currently has no ill effect on play other than possibly making is marginally easier to hit the piano.
First off... Is this slight tilt normal for this post?
If not, should I leave well enough alone or attempt a repair? Never done it, but I'm assuming I would pull the post, epoxy, redrill and reinsert. Is this generally the best or recommended fix for something like this? Alternative solution? Is the epoxy as or harder than the wood it replaces? I certainly don't want to makes things worse.
Which epoxy is the best for something like this?
