New TZ owner here, I have an error on startup of "pinball missing in gumball machine", but the game seems to play fine. In the gumball machine I see two pinballs and the powerball. What does the error mean?
Hey mdclips you should checkout the manual page 1-20 and 1-21. It has a good explanation of the switches and opto's related to the gumball machine loading. Do you have a dot when Free Play is shown on the pin? Still may be an error or something intermittent.
Quoted from mdclips:In the gumball machine I see two pinballs and the powerball.
When the balls are in their proper resting position, you should only be able to see two of the three balls. The next ball to be released will be below your line of sight when playing.
OK - got it. I looked at the manual, and didn't even see that error listed. However, I ran through the continuous gumball test, and everything looked good. Then I restarted the machine and had no errors. So I guess all is fine. I played a couple games and never had a problem. No credit dot now.
This page was printed from https://pinside.com/pinball/forum/topic/tz-pinball-missing-in-gumball-machine and we tried optimising it for printing. Some page elements may have been deliberately hidden.
