Hey all,
The piano switch is giving me hard time, the switch #43 very close to the start of the subway, sometimes the ball gets stuck in the subway just in front of the switch blade, doesn't have enough speed to travel through it, to a point now its much better than when i 1st got the machine, have tried different switches, modified multiple blade angles, even tied a switch wire but its to thin & was no good. PF pitch is at max,
is this a common issue & anything else i can do.
The other issue is the bridge divert gate, it sometimes doesn't dump the ball out the back, most of the time its ok, sometimes it tips over the side & flys off the wire form, ball looks to hit RHS of the bridge as it tips back, I've messed around bending & tweaking the metal flaps/return & even stretched out the opening, was going to try that magnet mod but that wont help the PB,
wire form is fitted nice, not under any stress & bridge pivots freely,
looking for some input.
thanks
