The mini playfield magnets are no longer activating when battle the power mode is active.
I have tested all of the switches (opto - opens diverter, switch entering top of mini play field, optos for exiting top and bottom on mini playfield. I have also tested the magnets in solenoid and magnet test sections. All are working properly. I reseated all of the plugs, switched the data cable between CPU and Driver board, reseated data cable between CPU and Fliptronics board.
Any ideas? Thank you in advance!
