Greetings from Australia, hoping for some advice for an amateur/hobby owner here,
On my Twilight Zone I can't get the two 555 globes in the overhead lamp above the mini playfield / powerfield to light up anymore.
I've checked the globes with an ohmmeter / new globes, no joy. The large flasher globe in the same lamp works just fine.
Tracing the wiring it looks like an orange and orange/white wire pair... i reseated the harness connector under the playfield... no joy,
Where to from here? I'm guessing i need to look to wherever the GI power comes from - would these two lamps have their own independent wiring and is that in the switch matrix or something like that?
All other GI is working just fine.
If i'm reading the manual right, these lamps are GI #02, on playfield J121-2 and backbox J-120-2 for voltage and J121-6 and J120-8 for drive, white-orange wiring... should i be looking to those locations for a broken connection? I know where J120 is in the backbox... should i be looking for a particular GI header under the playfield as well?
FWIW, my J120 GI IDC header in the backbox was all crispy so a few years ago i replaced it using crimped on trifurcon connectors.. but maybe i should check the #2 wire on the J120 in the backbox and make sure i didn't do a flaky job there?
Is there anything else I should be looking at?
thanks all!
