(Topic ID: 286509)
TZ- cabinet bottom separating from back
By pindude80
  • 7 posts
  • 4 Pinsiders participating
  • Latest reply 3 years ago by pindude80
#1 3 years ago
A few years ago I bought a restored twilight zone. The last time I moved it I noticed the bottom of the cabinet had pulled away from the back of the cabinet. I never got around to fixing it and kind of forgot about it.
I just moved the game again and want to get this fixed. What would be the repair method for this. Could I get some wood glue into the seam and wrap ratchet straps around the game until the glue dried? I would prefer a fix that is not too in-depth because the cabinet has already been finished and painted.
Any help and suggestions are greatly appreciated!
20210124_215038 (resized).jpg20210124_215038 (resized).jpg20210124_215104 (resized).jpg20210124_215104 (resized).jpg20210124_215125 (resized).jpg20210124_215125 (resized).jpg20210124_215153 (resized).jpg20210124_215153 (resized).jpg20210124_215200 (resized).jpg20210124_215200 (resized).jpg
#2 3 years ago
Weekend bump for repair ideas or suggestions
#3 3 years ago
Looks minimal, I would probably just leave it. If you feel you have to do something about it, get a little wood glue in there and use a few pipe clamps long enough to clamp the back panel and the front coin door panel vs ratchet straps.
#4 3 years ago
Quoted from no-extra-balls:
No-extra-balls, thanks for the reply! I agree it is pretty minimal but my concern was when I was moving the game I saw the back and bottom flexing apart and didn't want it to get any worse.
I had also thought about getting some wood glue in the gap but I'm not sure how to go about getting the glue in there because there isn't much of a gap on the inside of the cabinet; the gap is the widest on the bottom side of the cabinet and this would be the optimum place to put the wood glue but I don't think that would work because the glue would probably all run out. Maybe I'll try to get some in there and clamp it quickly before it runs out.
#5 3 years ago
Quoted from pindude80:
What about using a syringe with wood glue to squeeze the glue into the gap? You may need to drill a small hole to get the syringe into the gap (I'd drill from under the cabinet, so less noticeable). You could also use a piece of quad (similar to used between the side walls and base) to secure the back wall and base together - do that after you've pulled the pieces in with the pipe clamp.
#6 3 years ago
MDF board will naturally shrink with age, as it is a processed material with wax built in it. Since it is inherently not structural minor gluing and clamping should be fine.
If it really bothers you you can build a poplar bottom. That’ll solve it permanently.
I insert glue by actually using wood sticks lightly pressed in to increase the gap, pour glue in and use large clamps overnight. Gorilla wood glue is great.
#7 3 years ago
Quoted from underlord:
Underlord, thanks for the reply and great suggestion about using the wood sticks to open up the gap! I am completely fine with just using wood glue and not building a whole new bottom for it. I will probably use tapered wood shims to drive in the gap to open it up for glue. I will stop at the store and get some gorilla Wood glue. Thanks again!
$ 24.00
Various Novelties
Pinball Photos LLC
8,800
Uniontown, OH
$ 73.00
Pixels Arcade Games
$ 12.95
$ 19.95
Mitchell Lighting
$ 49.99
$ 115.00
pinballmod
10,000 (OBO)
Mount Pleasant, WI
$ 79.50
$ 115.00
pinballmod
$ 14.95
Pinball Pimp
$ 45.00
Just 3D Mods
$ 45.00
$ 21.99
Lee's Parts
7,500 (OBO)
Fairfield, CT
$ 49.99
$ 6.00
Arcade Upkeep
$ 399.00
$ 119.95
pinballmod
Corona, CA
$ 90.00
pinballmod
$ 109.99
$ 129.50
$ 159.00
Sparky Pinball
$ 34.99
Rubber/Silicone
NO GOUGE PINBALL™
This page was printed from https://pinside.com/pinball/forum/topic/tz-lower-cabinet-separating-from-back and we tried optimising it for printing. Some page elements may have been deliberately hidden.
