New! Dark mode!
(Topic ID: 268667)
TZ lamps stuck on temporarily
By EightiesArcade
5 months ago
  • 5 posts
  • 4 Pinsiders participating
  • Latest reply 5 months ago by Coyote
#1 5 months ago
Hello,
I have 3 lamps on my Twilight Zone, each appear from different rows and columns, which stay stuck on for a set period of time, then begin to function properly. If I watch them in attract mode, it appears that they always begin to stay stuck on at the exact same time, at the same pattern time. I’ve watched a few attract mode videos and they shouldn’t be doing this. I’m thinking there might be an issue with a diode, but not sure.
#2 5 months ago
Whenever weird things happen like this, try reseating the ribbon cables, in particular the short one between the CPU and PDB.
#3 5 months ago
Quoted from schudel5:
This. I would actually consider replacing this one or all of them eventually. If they are factory original I would replace and don't look back. This time it's lights. Next time it could be a flasher or a coil.
#4 5 months ago
So after troubleshooting with the ribbon cables, the lamps still stayed stuck on temporarily. I switched the 3 lamps to incandescent as another troubleshooting method and they function properly. Not sure why this is. The rest of the game is LED. Is this still a ribbon cable issue?
#5 5 months ago
Quoted from EightiesArcade:
Are you using an LEDOCD in the game?
$ 14.95
$ 59.95
pinballmod
$ 999.00
$ 54.99
$ 40.00
Lighting - Backbox
YouBentMyWookie
$ 100.00
Professor Pinball
$ 22.50
Stevenson Ranch, CA
$ 50.00
$ 75.00
$ 8.50
North Port, FL
$ 399.95
Pin Stadium Pinball Mods
$ 132.00
pinballmod
$ 57.95
PinBoss Mods
7,900
San Diego, CA
$ 16.00
$ 999.00
$ 40.00
Arcade Arts
$ 99.95
pinballmod
PinSound
$ 12.00
$ 499.95
